import RPi.GPIO as GPIO
class RotaryEncoder:
CLOCKWISE=1
ANTICLOCKWISE=2
BUTTONDOWN=3
BUTTONUP=4
rotary_a = 0
rotary_b = 0
rotary_c = 0
last_state = 0
direction = 0
# Initialise rotary encoder object
def __init__(self,pinA,pinB,button,callback):
self.pinA = pinA
self.pinB = pinB
self.button = button
self.callback = callback
GPIO.setmode(GPIO.BCM)
# The following lines enable the internal pull-up resistors
# on version 2 (latest) boards
GPIO.setwarnings(False)
GPIO.setup(self.pinA, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(self.pinB, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(self.button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# For version 1 (old) boards comment out the above four lines
# and un-comment the following 3 lines
#GPIO.setup(self.pinA, GPIO.IN)
#GPIO.setup(self.pinB, GPIO.IN)
#GPIO.setup(self.button, GPIO.IN)
# Add event detection to the GPIO inputs
GPIO.add_event_detect(self.pinA, GPIO.FALLING, callback=self.switch_event)
GPIO.add_event_detect(self.pinB, GPIO.FALLING, callback=self.switch_event)
GPIO.add_event_detect(self.button, GPIO.BOTH, callback=self.button_event, bouncetime=200)
return
# Call back routine called by switch events
def switch_event(self,switch):
if GPIO.input(self.pinA):
self.rotary_a = 1
else:
self.rotary_a = 0
if GPIO.input(self.pinB):
self.rotary_b = 1
else:
self.rotary_b = 0
self.rotary_c = self.rotary_a ^ self.rotary_b
new_state = self.rotary_a * 4 + self.rotary_b * 2 + self.rotary_c * 1
delta = (new_state - self.last_state) % 4
self.last_state = new_state
event = 0
if delta == 1:
if self.direction == self.CLOCKWISE:
# print "Clockwise"
event = self.direction
else:
self.direction = self.CLOCKWISE
elif delta == 3:
if self.direction == self.ANTICLOCKWISE:
# print "Anticlockwise"
else:
self.direction = self.ANTICLOCKWISE
if event > 0:
self.callback(event)
return
# Push button up event
def button_event(self,button):
if GPIO.input(button):
event = self.BUTTONUP
else:
event = self.BUTTONDOWN
return
# Get a switch state
def getSwitchState(self, switch):
return GPIO.input(switch)
# End of RotaryEncoder classBut how would I modify it so it can shows what sector the wheel is at. the encoder is in the middle and would rotate was the wheel rotate.
The wheel is 12 sectors. So based on the old A , old B, A , B have 16 combinations which can take care of 12 sectors.
