Temperature sensor and MySQL
Posted: Sun Jun 15, 2014 3:57 pm
by Anthonyfromtheuk
I have a bit of python code that prints on screen the current temperature detected by a ds18b20 sensor.
Here is the end of the code detecting the temperature from the sensor, that bit works and it prints the current temperature on the screen, but i get an error when trying to insert in to MySQL.
outputmain= temp[1][-6:-4]
outputdecimel= temp[1][-3]
finaloutput= outputmain+"."+outputdecimel
print finaloutput
db = MySQLdb.connect("host", "username", "password", "tablename")
curs=db.cursor()
curs.execute ("""INSERT INTO tablename values(CURRENT_DATE(), NOW(), 'Place',finaloutput)""")
db.commit()
print "Database Updated."
db.close()
I would like to be able to use the same "variable" finaloutput and insert it in to a mysql database.
But instead it prints the temperature on screen and then i get the error:
  File "test.py", line 39, in <module>
  File "/usr/lib/python2.7/dist-packages/MySQLdb/cursors.py", line 174, in execute
    self.errorhandler(self, exc, value)
  File "/usr/lib/python2.7/dist-packages/MySQLdb/connections.py", line 36, in defaulterrorhandler
    raise errorclass, errorvalue
_mysql_exceptions.OperationalError: (1054, "Unknown column 'finaloutput' in 'field list'")
What am i doing wrong here please?
here is the table i am trying to insert in to.
| Field       | Type          | Null | Key | Default | Extra |
| tdate       | date          | YES  |     | NULL    |       |
| ttime       | time          | YES  |     | NULL    |       |
| zone        | text          | YES  |     | NULL    |       |
| temperature | decimal(10,0) | YES  |     | NULL    |       |
Hope that makes sense, Thank you
Re: Temperature sensor and MySQL
Posted: Sun Jun 15, 2014 4:45 pm
by rpdom
I don't know Python, or how it interfaces to MySQL, but it looks like you are running the MySQL command
INSERT INTO  tablename values(CURRENT_DATE(), NOW(), 'Place',finaloutput);
where you really wanted to do something like
INSERT INTO  tablename values(CURRENT_DATE(), NOW(), 'Place',23.3);
You are using the literal "finaloutput" and MySQL is assuming that is the name of a column in the table, which it isn't.
You need to send the contents of the Python variable "finaloutput".
It's probably one of these two lines
curs.execute ("""INSERT INTO tablename values(CURRENT_DATE(), NOW(), 'Place'," + finaloutput + ")""")
curs.execute ("""INSERT INTO tablename values(CURRENT_DATE(), NOW(), 'Place'," . finaloutput . ")""")
depending on the way python does concatenation.
Posted: Sun Jun 15, 2014 4:58 pm
by Anthonyfromtheuk
I got it working with this:
curs.execute ("""INSERT INTO tablename values(CURRENT_DATE(), NOW(), 'Place',"%s")""",finaloutput)
I say working, its sort of working it puts the data in the column with Single quotations around it for example '21.6'
Edit removing the quotations around %s gives me just the temperature 21.6 in the databases column
Posted: Mon Jun 16, 2014 12:45 pm
by IanH2
According to the MySQLdb user guide, you need to make the items into a tuple:
c=db.cursor()
max_price=5
c.execute("""SELECT spam, eggs, sausage FROM breakfast
          WHERE price < %s""", (max_price,))
In your example, something like this:
curs.execute ("""INSERT INTO tablename values(CURRENT_DATE(), NOW(), 'Place',%s)""",(finaloutput,))
HOWEVER!!!
Please don't ever use Python string interpolation (i.e. "some-string" % (variables) ) to insert parameters into SQL statements. That way lies SQL injection, probably the biggest single cause of web site security failure.
There's some discussion of using MySQLdb and Python variables here: http://stackoverflow.com/questions/7752 ... -variables
