jojo_angelov
ValueError: The channel sent is invalid .." Pin 2
Sun Jun 15, 2014 3:40 am
So I have a tiny little fan connected to pin 6(Ground) and pin 2. I am trying to manually start and stop the fan when needed but I am getting this error when trying:
ValueError: The channel sent is invalid on a Raspberry Pi
Here is my code that I am executing as root. It seems to be working on other pins but not Pin 2
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(2, GPIO.OUT, pull_up_down=GPIO.PUD_UP)
I am not sure how to access this pin. Is there something I am doing wrong?
Re: ValueError: The channel sent is invalid .." Pin 2
Sun Jun 15, 2014 5:25 am
Pin 2 is a 5 volt power pin. It is a fixed output. (actually a direct connection to the 5v input on the Pi).
Return to “Python”
