mahjongg
Re: Python Usage Guide
Tue Apr 17, 2018 11:33 am
gkreidl wrote:
Mon May 15, 2017 6:33 am
AshPowers wrote:I would like to compile my program into a binary executable as it will be part of a product and do not want the source code being so easily obtainable.
What is the best method of doing this?
Thanks!
Nuitka.
http://nuitka.net/
Not for the raspberry PI.
Besides the canonical python compiler is pypy, not this commercial offering.
gkreidl
Tue Apr 17, 2018 3:00 pm
Thanks!
Nuitka.
http://nuitka.net/
About every word you wrote is wrong!
1. The Debian archive is processor independent and works very well on the RPi. omxplayerGUI, rtranscode (and it's web module) have all been compiled with nuitka for quite some time.
2. There is nothing "canonical" about pypy and it does not create binaries. It's a JIT compiler. It's fast, but often unusable because it may use too much memory (I've seen it using 6 times more memory compared to original Python or Nuitka).
3) Nuitka is not commercial but Open Source.
Minimal Kiosk Browser (kweb)
mahjongg
Re: STICKY: Python Usage Guide
Wed Apr 18, 2018 11:35 am
Luckily there weren't many of them. :P
PyPy is "canonical" in IMHO as it was the first and for a long time only "python compiler" I had heard off. But I realize now that is was not intended for this purpose.
but yes, if noitka works, and is fee (as in speech), then why not.
jacobgoona
Fri Oct 30, 2020 12:03 am
So it’s my understanding that Thonny is a good tool for learning Python. Did I get it right? If so, is it also ok to use Thonny for real-life projects or it’s specifically just for learning. I’m really sorry if my questions sound super stupid, but I’m just a total newbie at this point, though I’m totally determined to wrap my head around it :)
hippy
Fri Oct 30, 2020 7:39 pm
You would have been better off starting a new thread rather than necroing an old one.
Thonny is a good tool for both learning Python and developing code. Once code has been developed and deployed to a Pi as a 'real project' that code will normally be started by 'cron' or via /etc/rc.local and Thonny isn't required to do that.
jacobgoona
Sat Oct 31, 2020 2:14 pm
Good point about necroing. Thanks :)
Got it about Thonny and real-life projects. Much appreciated.
Loonhaunt
Sat Oct 31, 2020 10:21 pm
Where is the best place to get syntax help with Python 3. I have not written code for about 6 years. Memory has failed me!
B.Goode
Sat Oct 31, 2020 11:20 pm
https://www.python.org/
AlCap3003
Sat Nov 07, 2020 1:55 pm
Thanks for answering it anyway. Just started with Python and I'm a little lost rn. I'm gonna give Thonny a try. :)
ThomasWeek
Mon Dec 07, 2020 8:40 am
Python is an easy to learn, powerful programming language. It has efficient high-level data structures and a simple but effective approach to object-oriented programming. Python’s elegant syntax and dynamic typing, together with its interpreted nature, make it an ideal language for scripting and rapid application development in many areas on most platforms.
Return to “Python”
