VeryNoob
Short / Long Press GPIO
Sun May 25, 2014 8:18 am
I've done a write up on my internet radio here.
I want to cut the number of buttons down to 5 (On, prev, next, play, stop/off). Basically I want it so that if I hold down the off button for say 5 seconds, it shuts down. Mostly to stop accidental shutdowns.
I tried adding it using the idea from here, but it didn't work.
Any ideas?
DeeJay
Re: Short / Long Press GPIO
Sun May 25, 2014 8:37 am
VeryNoob wrote:it didn't work.
I think you might need to post the code you are using and a schematic of the circuit you have connected to get useful suggestions?
alexeames
Sun May 25, 2014 9:46 pm
VeryNoob wrote:I've done a write up on my internet radio here.
Any ideas?
I did exactly this with my RasPiCamcorder scripts.
Have a look over at GitHub
https://github.com/raspitv/RasPiCamcord ... corder2.py
Lines 164-184 of that script do exactly what you want.
Alex Eames RasPi.TV, RasP.iO
VeryNoob
Mon Jun 02, 2014 1:08 pm
I've tried a lot of things, but below is what seemed to get the closest. Rather than shutdown (which was painful, it kept shutting down the machine), I had a long press of the play button stop the music.
I looked at the RasPiCamcorder scripts, but it confused me.
Can anyone tell me what I am doing wrong?
  while 1:
	  if ( GPIO.input(NEXT) == False ):
		os.system("mpc next")
	  if ( GPIO.input(PREV) == False ):
		os.system("mpc prev")
	  if ( GPIO.input(PLAYBUTTON) == False ):		#if you press the PLAYBUTTON
		os.system("mpc play")						#then play the music
		for i in range(30):							#start counting
			if ( GPIO.input(PLAYBUTTON) == False ):	#if it is still being pressed
				print "pressed and released"		#print something
				j = j + 1							# add something to J
			if j >= 25:							# if you have been pressing for 28*0.1=2.8 seconds then
				os.system("mpc stop")			# stop playing the music
				print "stop playing music"
				#break
		time.sleep(0.1)							# wait 0.1sec, then loop again to see if you are holding the PLAYBUTTON still
		if ( GPIO.input(POWEROFF) == True ):
         	lcd_byte(LCD_LINE_1, LCD_CMD)
          	lcd_string("+------------------+",1)
          	lcd_byte(LCD_LINE_2, LCD_CMD)
          	lcd_string("|   Shutting Down  |",1)
          	lcd_byte(LCD_LINE_3, LCD_CMD)
          	lcd_string("|    Please Wait   |",1)
          	lcd_byte(LCD_LINE_4, LCD_CMD)
		#os.system("sudo shutdown -h now")
		time.sleep(2)
	  f=os.popen("mpc current")
	  station = ""
	  for i in f.readlines():
		station += i
          station = station + " " * 80
          stationa=station[0:20]
          stationb=station[20:40]
          stationc=station[40:60]
          stationd=station[60:80]
	  # Send some text
	  lcd_string(stationa,1)
	  lcd_string(stationb,1)
	  lcd_string(stationc,1)
          lcd_string(stationd,1)
  time.sleep(20)
SteveSpencer
Mon Jun 02, 2014 1:15 pm
Python isn't exactly my thing, but you seem to be changing j (used to determine a long press) when the button is released.
Also, you aren't resetting it anywhere in that code.
When you detect a press (at all) of the button, you can loop (and count or time) until the button is released.
Once that happens, work out whether it's a long press, or a short press, and act accordingly.
I do a similar thing with a headless Pi I use as a music server, so I can shut it down without having to remote onto it.
A short press means to pause/resume, useful when the phone rings, whereas a long press means shut down the Pi.
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
VeryNoob
Mon Jun 02, 2014 1:56 pm
Hi Steve,
Good point about resetting J. Can you post the code that you used for your music server so that I can have a look at it?
SteveSpencer
Mon Jun 02, 2014 2:59 pm
Not really, it isn't Python, and as I am at work, I don't have access to the code right now. (Also, I am in the middle of refitting the room I use as an office, so haven't used my development Pi for around a week or so :( )
Obviously, the binary code is on an SD in another Pi, but that won't help either.
In simple terms, though, I look and see if the GPIO is pressed. In your case, that's the GPIO.input(PLAYBUTTON) state.
If it is, I set a variable to the current time (including milliseconds), and then go into a loop where I sleep for a small amount of time,
then check the state again. If the state has changed, then the button has been released.
So I set a variable to the difference between the current time (i.e. after the release) and the time when I noticed it was pressed.
That gives me the "hold" time for the button, and I work it out from there.
As I say, I'm not a python programmer, so I don't know how you'd do the time stuff in python - it's relatively simple in C or C++, and I'm sure someone around here would be able to tell you. (I am intending to learn python, but I have other non-Pi calls on my time, [including work!] so it's not exactly a priority right now...)
Steve S
VeryNoob
Tue Jun 03, 2014 1:30 pm
this sort of works
A problem is that if you pause the music, then you can't hit play for a while (3 seconds). Even if you wait, sometimes the play buttons doesn't work, and you have to wait another 3 seconds. I think it's something to do with the polling interval, but I could be wrong. This will be less of an issue when the long press is used for shutdown.
Also, see the last if statement #if ( GPIO.input(POWEROFF) == True ): . For some reason this code always gets run now, even though I haven't changed it, at least that I can see. Any ideas?
Hopefully I'll get this mastered soon, and then I'll update my "guide" (a very optimistic term for it)
def main():
	# Main program block
	GPIO.setmode(GPIO.BCM)       # Use BCM GPIO numbers
	GPIO.setup(LCD_E, GPIO.OUT)  # E
	GPIO.setup(LCD_RS, GPIO.OUT) # RS
	GPIO.setup(LCD_D4, GPIO.OUT) # DB4
	GPIO.setup(LCD_D5, GPIO.OUT) # DB5
	GPIO.setup(LCD_D6, GPIO.OUT) # DB6
	GPIO.setup(LCD_D7, GPIO.OUT) # DB7
	GPIO.setup(NEXT, GPIO.IN) # Next Track
	GPIO.setup(PREV, GPIO.IN) # Previous Track
	GPIO.setup(PLAYBUTTON, GPIO.IN) # Play
	GPIO.setup(POWEROFF, GPIO.IN) # Volume Up by 5
	# Initialise display
	lcd_init()
	# Send some test
	lcd_string(startupline1,2)
	lcd_string(startupline2,2)
	lcd_string(startupline3,2)
	lcd_string(startupline4, 2)
	os.system("mpc play 1")
	time.sleep(1)
	while 1:
			PRESSTIME = 0
			for j in range(30):							#start counting
					PRESSTIME = PRESSTIME + 1							# add something to J
				if ( PRESSTIME >= 25 ):								# if you have been pressing for 28*0.1=2.8 seconds then
					#break
		#	os.system("mpc stop")
		#	lcd_byte(LCD_LINE_1, LCD_CMD)
		#	lcd_string(shutdownline1,1)
		#	lcd_byte(LCD_LINE_2, LCD_CMD)
		#	lcd_string(shutdownline2,1)
		#	lcd_byte(LCD_LINE_3, LCD_CMD)
		#	lcd_string(shutdownline3,1)
		#	lcd_byte(LCD_LINE_4, LCD_CMD)
		#	lcd_string(shutdownline4,1)
			#os.system("sudo shutdown -h now")				# This is hashed out, so that the system doesn't keep turning off while I am experimenting with the code
		#time.sleep(2)
		station = ""
			station += i
		# Send some text
	time.sleep(20)
VeryNoob
Tue Jun 03, 2014 11:30 pm
Woo hoo. Got it working. It's a little rough around the edges. The buttons aren't always super responsive, but it works. :D
Eventually I will get it set up with only three switches.
  1. Previous
  2. On (via a DPST. One pole to the GPIO, one to Pi-Supply), Play/ Stop and long press shutdown
  3. Next
I'm going to leave this project for a while, and have a go at a similar radio using an adafruit LCD plate and usual panics work as a base.
I'll update my Lunchbox Internet Radio Guide thread with pics, the code, and the new wiring later. But for now, here is the code, if anyone has any suggestions for improvements.
#!/usr/bin/python
# Script for Raspberry Pi Internet Radio
# import
import RPi.GPIO as GPIO
import time
import os
PRESSTIME = 0
PLAYING = False
# Define GPIO to LCD mapping
LCD_RS = 25 # LCD Pin 4
LCD_E  = 8 # LCD Pin 6
LCD_D4 = 4 # LCD Pin 11
LCD_D5 = 10 # LCD Pin 12
LCD_D6 = 9 # LCD Pin 13
LCD_D7 = 11 # LCD Pin 14
# Define GPIO for Radio Controls
# Button 1 goes to the Pi-Supply to turn the computer on
PREV = 23 # Button 2 - Previous track. Black wires
PLAYBUTTON = 27 # Button 3 - Play. Green Wires
STOPOFF = 22 # Button 4 - Brown wires. Press for stop. Long press for shutdown.
NEXT = 24 # Button 5 - Grey wires. Next track.
# Define some device constants
LCD_WIDTH = 20    # Maximum characters per line
LCD_CHR = True
LCD_CMD = False
LCD_LINE_1 = 0x80 # LCD RAM address for the 1st line
LCD_LINE_2 = 0xC0 # LCD RAM address for the 2nd line
LCD_LINE_3 = 0x94 # LCD RAM address for the 3rd line
LCD_LINE_4 = 0xD4 # LCD RAM address for the 4th line
# Timing constants
E_PULSE = 0.00005
E_DELAY = 0.00005
# What do you want the display to say when it's loading
startupline1 = "+------------------+"
startupline2 = "|   Raspberry Pi   |"
startupline3 = "|  Internet Radio  |"
startupline4 = "+------------------+"
shutdownline1 = "+------------------+"
shutdownline2 = "|   Shutting Down  |"
shutdownline3 = "|    Please Wait   |"
shutdownline4 = "+------------------+"
stopline1 = "+------------------+"
stopline2 = "|       Music      |"
stopline3 = "|      Stopped     |"
stopline4 = "+------------------+"
def main():
	GPIO.setup(STOPOFF, GPIO.IN) # Short Press is stop, long press is shutdown
	lcd_init()
	# Send some test
	PLAYING = True
	time.sleep(2)
	while 1:
		if ( GPIO.input(NEXT) == False ): #if you press the next button
			os.system("mpc next") # then play the next song
			PLAYING = True
		if ( GPIO.input(STOPOFF) == False ):
			PLAYING = False
			PRESSTIME = 0
			for j in range(50):							#start counting
				if ( GPIO.input(STOPOFF) == False ):	#if it is still being pressed
					print "pressed the stop button"		#print something
					PLAYING = False
					lcd_string(stopline1,1)
					lcd_string(stopline2,1)
					lcd_string(stopline3,1)
					lcd_string(stopline4,1)
					PLAYING = False					# stop playing the music
					os.system("sudo shutdown -h now") # shutdown the machine
					print "the shutdown command has been sent"
					time.sleep(180)	# this pauses the script, so it doesn't go back into the loop, while the RPi shuts down.
		if ( PLAYING == False ): # if the music is supposed to be stopped, then show the stop screen
			time.sleep(0.1)
		if ( PLAYING == True ): # If the music is playing, then show the MPC output of what is playing.
			station = ""
				station += i
			# Send some text
	time.sleep(20)
def lcd_init():
	lcd_byte(0x33,LCD_CMD)
	lcd_byte(0x32,LCD_CMD)
	lcd_byte(0x28,LCD_CMD)
	lcd_byte(0x0C,LCD_CMD)
	lcd_byte(0x06,LCD_CMD)
	lcd_byte(0x01,LCD_CMD)
def lcd_string(message,style):
	# Send string to display
	# style=1 Left justified
	# style=2 Centred
	# style=3 Right justified
	if style==1:
		message = message.ljust(LCD_WIDTH," ")
	elif style==2:
		message = message.center(LCD_WIDTH," ")
	elif style==3:
		message = message.rjust(LCD_WIDTH," ")
	for i in range(LCD_WIDTH):
		lcd_byte(ord(message[i]),LCD_CHR)
def lcd_byte(bits, mode):
	# Send byte to data pins
	# bits = data
	# mode = True  for character
	#        False for command
	GPIO.output(LCD_RS, mode) # RS
	# High bits
	GPIO.output(LCD_D4, False)
	GPIO.output(LCD_D5, False)
	GPIO.output(LCD_D6, False)
	GPIO.output(LCD_D7, False)
	if bits&0x10==0x10:
		GPIO.output(LCD_D4, True)
	if bits&0x20==0x20:
		GPIO.output(LCD_D5, True)
	if bits&0x40==0x40:
		GPIO.output(LCD_D6, True)
	if bits&0x80==0x80:
		GPIO.output(LCD_D7, True)
	# Toggle 'Enable' pin
	time.sleep(E_DELAY)
	GPIO.output(LCD_E, True)
	time.sleep(E_PULSE)
	GPIO.output(LCD_E, False)
	time.sleep(E_DELAY)
	# Low bits
	if bits&0x01==0x01:
	if bits&0x02==0x02:
	if bits&0x04==0x04:
	if bits&0x08==0x08:
	time.sleep(E_DELAY)
	time.sleep(E_PULSE)
	time.sleep(E_DELAY)
if __name__ == '__main__':
	main()
  # End of File
Return to “Python”
