benjp
Using Python to detect my iPhone
Fri May 23, 2014 4:22 pm
I have created a python program that auto-starts when my Raspberry Pi boots up. I don't want the program to take any action while I am home. I figure that a cool way to do this would be for the program to determine if my phone is connected to my wireless network or not. I've been toying around with having the program ping my phone periodically to see if its on the network, but I can't figure out how to turn the result of the ping into information the python program can use. Any ideas or examples out there? Thanks!
FLYFISH TECHNOLOGIES
Re: Using Python to detect my iPhone
Fri May 23, 2014 4:30 pm
benjp wrote: can't figure out how to turn the result of the ping into information the python program can use.
An universal solution (applicable also to bash scripting, etc.) is to redirect output of a command to a file and then parse this file.
Output of the command can be redirected to a file using this syntax:
ping -c 1 192.168.0.1 > /tmp/ping_output
Another option is to chain more programs/scripts using pipe for data exchange between them.
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
Fri May 23, 2014 5:30 pm
Your problem is that you don't know the IP address. You can discover the MAC address of it's WiFi but with a DHCP network that can be assigned to any IP address from your DHCP pool (and if the lease expires or the DHCP server is restarted it will be different).
There's a crude way to scan the network from a bash script
#!/bin/bash
 for i in `seq 30 100`
 do
   ping -c1 -W1  192.168.1.$i
 done
And we can see which stations are alive with
 arp -an | grep ':'
The alternative (and better) way is to use nmap
sudo apt-get install nmap
sudo nmap -sn 192.168.1.0/24
which does a much faster ping sweep and does some decoding on MAC addresses.
This is a doctor free zone.
benjp
Fri May 23, 2014 6:42 pm
@Flyfish - Can I ping the iPhone using its name? That way I can be sure that it will reach my phone even if its assigned a new IP? Could I do this?:
ping -c 1 bens-iphone > /tmp/ping_output
MadCow42
Fri May 23, 2014 8:19 pm
Set up your router to assign a static IP to your iPhone... most routers can do that. Then, you can ping that IP regularly to see if it's there.
I didn't think that an iPhone would respond to a ping by default, but mine does - just tested it.
So, piping the ping output to a file and parsing the file is not pretty, but it would work.
Kevin.
cyrano
Fri May 23, 2014 9:37 pm
benjp wrote:@Flyfish - Can I ping the iPhone using its name? That way I can be sure that it will reach my phone even if its assigned a new IP? Could I do this?:
Yes.
Unfortunately, with Lion, Apple has put a little gem out that's called "Bonjour Sleep Proxy". Any other Apple device might reply with your phone's name on a first call. Your router, if it's an Apple branded beast. Or an iMac on your network, or some other recent Apple compatible device, a NAS, for instance. It's a way to make battery powered devices "available" on the network while they are in deep sleep. Once it's really needed, the phone will wake up and take over from the proxy, of course. Otherwise, it would need to wake for each and every broadcast mdns call. :ugeek:
So you 'd need to experiment a bit with making multiple calls before deciding if it is your phone or the Sleep Proxy's ghost. Doing it that way will wake up the phone and shorten battery life.
And I'm afraid changing to MAC adress might face the same problem, since even MAC addresses get proxied, IIRC.
And it will make some people hate RendezVous/Bonjour/Avahi/ZeroConfig... even more.
david_wallis
Sat May 24, 2014 7:49 am
What about using Bluetooth instead?
benjp
Tue May 27, 2014 8:04 pm
Thanks for the input everyone!
I've run into the problem when I ping the phone when it is locked, the ping fails. Wow, this is getting complicated real quick. Is there a way to get the iPhone to listen for pings without draining the battery?
@david_wallis - Didn't think about Bluetooth. Sounds like a good idea. I have no idea how to go about using it, though. Any pointers or webpages with examples?
RockTractor
Thu May 29, 2014 8:55 pm
It's my understanding that you can wake up your iPhone with a TCP three-way (Synchronize) handshake on port 62078.
oguime
Sun Jun 22, 2014 3:01 am
I'm also interested in detecting iPhones connected to my network.
Has anyone implemented this?
nekomatic
Wed Jul 02, 2014 10:39 pm
Does your wireless router have a status webpage you can access by http? If so, does it show information you could screenscrape and use to determine whether your iPhone is currently on, or has just joined, the network?
DigiPi
Wed Aug 27, 2014 4:50 am
I'm very interested in this as well and found the following
http://www.power-home.com/forum/forum_p ... p?TID=3250
So far I have been unsuccessful in reproducing
ph_sendsocketdata1 ( "192.168.1.92", 62078, 6, "\x16" )
with Python sockets though.
Paul Liddicott
Wed Aug 27, 2014 6:47 am
Hi Benjp,
Earlier this year I attended a Rpi course run by a colleague at work.
We used the Rpi to detect when a phone/laptop etc attempted to join a network.
this was done using MAC address of joining device,
The details are published on the IET website (see link).
http://mycommunity.theiet.org/communiti ... s/173/5822
It was all quite easy to set up, the only requirement was that the wifi card on the pi could operate in promiscuous mode to achieve packet sniffing.
Hope this is of some use.
Paul
domjacko
Fri Sep 05, 2014 10:45 pm
I've recently done a Python script to detect if a certain Bluetooth device is in range. It's a really neat way of detecting a device, but obviously the range would be an issue and you'd have to modify it to remove the LED bit and change to what you want
tronb
Wed Jan 21, 2015 9:38 pm
DigiPi,
Did you have any luck getting the code to work on python?
If you do, could you share your code?
Absimiliard
Wed May 24, 2017 8:33 am
I have implemented a daemon that check for my iphone using bluetooth. I write it in C++ using bluez and this doc
https://people.csail.mit.edu/albert/blu ... /x604.html
But it give you also samples in python in the same documentation :
My server is available on github : https://github.com/marc-despland/alarm-controller
The class that do the detection is src/blueping.cpp
Return to “Python”
