tewe
Minecraft Pi Edition API
Mon May 12, 2014 6:30 am
Hi!
I am a beginner when it comes to Python, I am trying to learn it using the Minecraft API. I am trying to make a program that places a GoldBlock instead of every block I step on. This is the code that I have written:
import minecraft.minecraft as minecraft
import minecraft.block as block
import time
mc = minecraft.Minecraft.create()
playerPosition = mc.player.getPos()
post = mc.postToChat
blockType = mc.getBlock(playerPosition.x, playerPosition.y -1, playerPosition.z)
if __name__ == "__main__":
	while ('True'):
		if not blockType == 9 or blockType == 0:
			mc.setBlock(playerPosition.x, playerPosition.y -1, playerPosition.z,block.GOLD_BLOCK)
	while ('True'):
In the later code is a WhileLoop. I am pretty sure that it is this part of the code that is incorrect. When I run the program from LXTerminal it runs properly. But it is only the block that the player stands on when the program executes that is transformed into gold.
I really appreciate all of your help!
I'm a swedish viking with big beard, I like to eat raspberry pi.
Re: Minecraft Pi Edition API
Mon May 12, 2014 7:33 am
You only read mc.getPos() & mc.getBlock() once.
Move those calls inside your while loop so that as you move you re-read the coordinates of the block to turn to gold.
elParaguayo
Mon May 12, 2014 8:29 am
As an aside, your code says:
while ('True')
True in inverted commas is the string True, rather than the True/False boolean value. You'd therefore normally have:
while True:
However the effect is the same, as any string other than an empty string is considered True in Python. See https://docs.python.org/2/library/stdtypes.html
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
tewe
Mon May 12, 2014 5:06 pm
Thank you for the help but it is still not working. I have tried to write another bit of code:
	while ('True'):
                        mc.postToChat ('GOLD!')
I added mc.postToChat ('GOLD!'). That command repeats over and over again. So it is not the loop that is the incorrect part I think.
elParaguayo
Mon May 12, 2014 6:27 pm
Did you see Dougie's comment?
These lines:
needs to be inside the While loop.
you're checking whether blockType is equal to a certain value, but you're not updating blockType to reflect the fact that your player is moving.
MattHawkinsUK
Mon May 12, 2014 6:51 pm
Also you probably want to use getTilePos rather than getPos as it will give you integers rather than floats.
playerPosition = mc.player.getTilePos()
blockType = mc.getBlock(playerPosition.x, playerPosition.y - 1, playerPosition.z)
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
Return to “Python”
