arginine
Display MPD info on a 4x20 LCD
Sat May 03, 2014 7:52 pm
I did a python script for displaying MPD (Music Daemon Player) information on a 4x20 LCD and then, I though it's worth sharing it with others (I received many helps on this forum !!!).
I used the updated RPLCD library (https://github.com/dbrgn/RPLCD).
The distribution is Volumio 1.2beta
The script below display the following :
first line : date and time
Second line : temperature from a dallas probe and cpu temperature
Third line : nothing
Fourth line : MPC volume (%) and current song countdown. The script works with songs with a maximum length of 24h. The display is adjusted automatically to fit on 18 characters (even if the volume is 6 %, 60% or 100%). Songs below one hour are displayed like 55:32, songs above one hour ---> 01:24:32.
You have to add a line in your act/rc.local file
/etc/init.d/mpd restart & ----> to be sure mpd is really started
(sleep 10; python /scripts/lcd.py)&
(sleep 5; irexec -d /root/.lircrc)& ---> this line is for my IR sensor
/var/www/command/player_wdog.sh startup & > /dev/null 2>&1
exit 0
On my setup, the script survive reboot, mpd restart (or stop). Please feel free to let me know any coding optimizations or errors you might see.
Francis
Result:
code : lcd.py
#!/usr/bin/python
# -*- coding: utf-8 -*-
#from __future__ import print_function, division, absolute_import, unicode_literals
import RPi.GPIO as GPIO
import time
import sys
import os
import glob
import subprocess
from RPLCD import CharLCD, cleared, cursor
from RPLCD import Alignment, CursorMode, ShiftMode
from time import sleep, strftime
from datetime import datetime
GPIO.setwarnings(False)
# Temperature from dallas probe DS18B20 - Start
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
base_dir = '/sys/bus/w1/devices/'
device_folder = glob.glob(base_dir + '28*')[0]
device_file = device_folder + '/w1_slave'
def read_temp_raw():
    f = open(device_file, 'r')
    lines = f.readlines()
    f.close()
    return lines
def read_temp():
    lines = read_temp_raw()
    while lines[0].strip()[-3:] != 'YES':
        time.sleep(0.2)
    equals_pos = lines[1].find('t=')
    if equals_pos != -1:
        temp_string = lines[1][equals_pos+2:]
        temp_c = str(int(temp_string) / 1000)
        return temp_c
# Temperature from dallas probe DS18B20 - End
# CPU temperature as a rounded integer - Start
def getCPUtemperature():
	res = os.popen('vcgencmd measure_temp').readline()
	res = float(res.replace("temp=","").replace("'C\n",""))
	res = int(round(res,0))
	res = str(res)
	return res
getCPUtemperature()
# CPU temperature as a rounded integer - End
# MPD Info - Start
def Get_MPC_info():
	subprocess_list = subprocess.check_output(('ps', '-A'))
	subprocess_list_mpd = subprocess_list.find("mpd")
	if subprocess_list_mpd == -1:
		mpd_info = " MPD not started!   "
		return mpd_info
	else:
		process = subprocess.Popen('mpc', shell=True, stdout=subprocess.PIPE)
		status = process.communicate()[0]
		statusLines = status.split('\n')
		#print statusLines
		# If MPC was not on "STOP"
		if len(statusLines) > 2:
				# Extract Volume (be sure that the mpc command return a value in volume (i.e not 'NA')
				mpc_vol= statusLines[2].replace("volume:","").replace(" ","").split('%')[0] + " %"
				#print "mpc vol = " + mpc_vol
				if len(str(mpc_vol)) == 3:
			 		mpc_vol = '0' + str(mpc_vol)
				timings_mpd = statusLines[1].split(' ')
				#print "timing mpd = " + str(len(timings_mpd))
				index_list = len(timings_mpd) -2
				#print "index = " + str(len(timings_mpd)-2)
				# Error handling
				if index_list <= 7:
					# Extract the song duration and the current duration played
					song_lengh = timings_mpd[index_list].split('/')[1]
					time_play = statusLines[1].split(' ')[index_list].split('/')[0]
					#print song_lengh
					#print time_play
					# Convert the durations in seconds
					song_lengh_sec=int(song_lengh.split(':')[0]) * 60 + int(song_lengh.split(':')[1])
					time_play_sec=int(time_play.split(':')[0]) * 60 + int(time_play.split(':')[1])
					# Calculate current song "countdown"
					count_down = int(song_lengh_sec) - int(time_play_sec)
					# Display the song count down (18 characters lengh)
					hours = count_down // 3600
					# Add a '0' if hours between 1-9
					if len(str(hours)) == 1:
		 				hours = '0' + str(hours)
					minutes = int((count_down % 3600) // 60)
					# Add a '0' if minutes between 1-9
					if len(str(minutes)) == 1:
						minutes = '0' + str(minutes)
					seconds = int(count_down % 60)
					# Add a '0' if seconds between 1-9
					if len(str(seconds)) == 1:
		 				seconds = '0' + str(seconds)
					if count_down >= 3600:
						count_down_display=  '{}:{}:{}'.format(hours, minutes, seconds)
						if len(mpc_vol) > 4: # Volume equals 100%
							spacer = "     "  # 5 spaces
						else :
							spacer = "      " # 6 spaces
					else:
						count_down_display =  '{}:{}'.format(minutes, seconds)
							spacer = "        " # 8 spaces
						else :
							spacer = "         " # 9 spaces
					mpd_info = " " + mpc_vol + spacer + count_down_display
				else:
					mpd_info = "                    " # 20 spaces
		else:
				mpd_info = " STOP         00:00 "
		#print " mpd info = " + mpd_info
		return mpd_info
# MPD Info - End
# Display section - Start
lcd = CharLCD()
# Define custom character (celcius degre sign)
degre_celcius= (0b00000, 0b00110, 0b00110, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000 );
lcd.create_char(0, degre_celcius)
lcd.clear()
while 1:
	# Row 1
	lcd.cursor_pos = (0, 0)
	lcd.write_string(" " + datetime.now().strftime('%a %d %b   %H:%M') + " ")
	# Row 2
	lcd.cursor_pos = (1, 0)
	lcd.write_string(" " + read_temp() + unichr(0) +"C" + "          " + getCPUtemperature() + unichr(0) +"C " )
	# Row 3
	lcd.cursor_pos = (3, 0)
	lcd.write_string(Get_MPC_info())
	#sleep(60)
# Display section - End
mecaz
Re: Display MPD info on a 4x20 LCD
Sat Nov 21, 2015 8:13 pm
I got following error when try to execute your script with python3.
sudo python3 lcd.py
File "led.py", line 154, in <module>
File "led.py", line 46, in Get_MPC_info
TypeError: Type str doesn't support the buffer API
What should i do?
Regards
dbrgn
Sat Nov 21, 2015 8:18 pm
Hi
The problem doesn't seem to be in your `Get_MPC_info` function. See the stack trace:
I can't really help you with your own code, but it might be that you need to pass in a byte string to the `find()` function: `subprocess_list.find(b"mpd")`.
mecaz
Sat Nov 21, 2015 10:36 pm
i added b before subprocess_list.find(b"mpd") and status.split(b'\n')
and now i am getting following error. may it be because of python3 ?
isnt it compatible with python3. how can i run this script properly?
sudo python3 led.py
File "led.py", line 158, in <module>
File "led.py", line 66, in Get_MPC_info
TypeError: expected bytes, bytearray or buffer compatible object
dbrgn
Sat Nov 21, 2015 10:52 pm
Ah, I somehow missed that you're talking about the code from the OP, which isn't your code...
In that case maybe @arginine can help you. RPLCD is Python 3 compatible, the `led.py` script maybe not.
Return to “Python”
