Anthonyfromtheuk
make script loop
Mon Apr 21, 2014 3:44 pm
I have this
#!/usr/bin/env python
from time import sleep
import os
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.IN)
state = GPIO.input(23)
if (state is False):
    print "Water detected!"
else:
   print "Water not detected"
Hope this makes sense...What I would like is for "else" to make the script check the state again. So it will just loop until the state is false when it will print "Water detected!"
have found some examples online but they are a bit confusing to me, can anybody help please?
paddyg
Re: make script loop
Mon Apr 21, 2014 4:04 pm
If you do
while GPIO.input(23):
  time.sleep(1) # don't print anything as you will get lots of lines, pause the maximum resolution you can get away with
# GPIO.input(23) must become false in order to drop out of loop
If you need your program to do other things you will have to set up something more sophisticated than this but you should make sure you understand what's going on first.
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
Anthonyfromtheuk
Mon Apr 21, 2014 4:08 pm
Got it working the way I want :D
now i can just run it once and if water is detected i will get a text message
import os, glob, time, sys, smtplib
from email.mime.text import MIMEText
import os
fortext= "Grow Bed water level is to high"
while True:
    if ( GPIO.input(23) == False ):
        USERNAME = "[email protected]"
        PASSWORD = "MYPASSWORD"
        MAILTO = "[email protected]"
        msg = MIMEText(fortext)
        msg['Subject'] = '#test'
        msg['From'] = USERNAME
        msg['To'] = MAILTO
        server = smtplib.SMTP('smtp.gmail.com:587')
        server.ehlo_or_helo_if_needed()
        server.starttls()
        server.login(USERNAME,PASSWORD)
        server.sendmail(USERNAME, MAILTO, msg.as_string())
        print "Text Message sent"
        server.quit()
        break
paddyg
Mon Apr 21, 2014 4:36 pm
Anthony, good. I hope the water being detected isn't anything catastrophic such as flood water entering your front door. Or if it is, that you never get that text message.
As sending a text message doesn't sound like a time critical control function you might want to put a sleep into your while loop outside the if block. Without that the processor will be running flat out.
croston
Mon Apr 21, 2014 4:52 pm
Your program would be much better if it used GPIO.wait_for_edge() rather than polling. A full explanation is here:
https://sourceforge.net/p/raspberry-gpi ... ki/Inputs/
Anthonyfromtheuk
Mon Apr 21, 2014 5:57 pm
I will check it out, didn't really think about it taxing the processor. Its all new to me! but good fun none the less when its working! :)
Anthonyfromtheuk
Mon Apr 21, 2014 5:58 pm
It is to detect overflow of an aquaponic grow bed.
paddyg wrote:Anthony, good. I hope the water being detected isn't anything catastrophic such as flood water entering your front door. Or if it is, that you never get that text message.
Anthonyfromtheuk
Mon Apr 21, 2014 6:00 pm
That seems useful, I intend to have this running as a background process from startup so I will have to figure out how to use that wait_for_edge
croston wrote:Your program would be much better if it used GPIO.wait_for_edge() rather than polling. A full explanation is here:
Return to “Python”
