Oldbitcollector
Better than os.start?
Sun Apr 13, 2014 8:26 pm
I'm running a Python script that currently uses an os.system [os.system("randomplay --basedir=/home/pi/music"] to launch an outside player. The script simply stops at that point to do the other job (randomplay).
Is there a better command which will launch the outside job, then continue on running the python script it was launched from while the other application is running?
Edit, I can add a & to the executed line, but then I'm not going to have access to the controls of the player.
Thanks in advance
Jeff
My Ongoing Raspberry Pi Reference: http://www.ledgerlabs.us/raspberrypi
Douglas6
Re: Better than os.start?
Sun Apr 13, 2014 9:00 pm
Take a look at subprocess.popen()
Richard-TX
Mon Apr 14, 2014 2:30 am
use the full pathname ie
 /usr/local/bin/randomplay -args
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
Return to “Python”
