Ant232
Quick time.sleep(????) question.
Sun Mar 23, 2014 1:47 pm
Can you have a variable in the time.sleep() method? i.e
Blah = 8
time.sleep(Blah)
I have been trying this but it doesn't seem to work. It's saying that it should be a float. I tried assigning 20.0 to it but still no luck.
Any ideas?
Thanks in advance..
Ant
Re: Quick time.sleep(????) question.
Sun Mar 23, 2014 1:52 pm
blah = 8.0
time.sleep(blah)
python numbers default to integers.
Ant232
Sun Mar 23, 2014 2:09 pm
Wow, thanks for the quick reply..
It seems to be receiving a float. Maybe I should explain what's happening.
Web form sends a number to a txt file via PHP.
Python reads the text file and assigns a variable from the result.
The variable is the used in the time.sleep() method.
f = open("/home/pi/webform/details.txt","r")
imglen = (f.readline())
print imglen
Then I have this in a loop:
            myProc=subprocess.Popen( [ "fbi", "--once", "-autoup", "-T", "1", "-noverbose", "-readahead" , infile])
            time.sleep(imglen)
            myProc.kill()
            myProc.wait()
When it reaches the time.sleep(imglen) it crashes the script and tells me it should be a float.
I have the 'print imglen' there to verify that it has the correct number assigned to it. When I start the script it outputs a float.
Ant
Sleep Mode zZ
Sun Mar 23, 2014 2:18 pm
When printed it seems to be a float but in reality it is a string. You have to convert the string to a float using the built-in float() function.
Ant232
Sun Mar 23, 2014 2:37 pm
That's it. All working now. Many many thanks for the replies.
One question for future reference. How did you know it was a string? Does it become a string when Python reads the textfile?
Thanks again.
Sleep Mode zZ
Sun Mar 23, 2014 3:03 pm
Ant232 wrote: One question for future reference. How did you know it was a string? Does it become a string when Python reads the textfile?
The readline() method reads a line from a textfile and returns it as a string.
355/113
Tue Mar 25, 2014 12:50 am
In case other people are as confused as I was at first on this issue, the answer to the op question "
Blah = 8
time.sleep(Blah)
is *yes*, you can use float variables in time.sleep()
I am using one to drive a servo with RPIO pwm function and my oscilloscope shows me that it does work. I just mention this because I had just written code yesterday and then saw this posting. The op got into problems by reading a text file which did not supply a float, only a string version.
HTH
Return to “Python”
