techpaul
Re: Binary Counter without using shift register such as 74HC
Sun Mar 16, 2014 11:35 am
Better code would setup the pins as outputs ONCE in main (or a function called from main.
Also not use a complicated
light((m * j) / m)
line just call the light function then use BINARY AND function to scan over the value and mask which bit to determine action, moving mask with >> or << operations.
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
techpaul
Sun Mar 16, 2014 2:08 pm
Untested but should work code to try using binary operations which is less overhead than a modulus operation (%) simple ands and shifts are easier to do.
Also only calls one function, whilst also only setting up GPIO as outputs ONCE
#!/usr/bin/env python3
#Date: 12th, March 2014
# modified and untested version only sets up pins as output once and
# simplified binary operations for lower overhead
# modified 16th March 2014 Paul Carpenter - PC Services
import RPi.GPIO as gpio
import time
gpio.setmode(gpio.BCM)
gpio.setwarnings(False)
# order of outputs first is LSbit of counter
iopins = [14, 15, 18, 17, 27, 22, 10, 9, 11]
# time delay between light changes
tdelay = 0.125
# Maximum count up to value
count = 511
def light( val ):
    maxk = 1
    for pin in iopins:
        if( val & mask ):
            gpio.output( pin, gpio.HIGH )
        else:
            gpio.output( pin, gpio.LOW )
        mask <<= 1
    return
if __name__=='__main__':
    # Set all pins as output
    for pin in iopins:
        gpio.setup( pin, gpio.OUT )
    # actual counting
    for j in range ( 0, count + 1 ):
        light( j )
        time.sleep( tdelay )
    # end tidy up
    gpio.cleanup( )
Mahdi
Wed Apr 22, 2015 7:58 pm
hey man :)
why do you define 9 GPIOs while u are using only 8 ?
techpaul
Wed Apr 22, 2015 9:27 pm
Mahdi wrote:hey man :)
Because the original was 9 bit code counting from 0 to 511, that is 512 steps which is 9 bits, that was the original contributors choice to use 9 bits
Using the SAME python construct of
for pin in iopins:
Actually means it always scans the array of 9 GPIO pin values, yes ALL 9
techpaul
Thu Apr 23, 2015 5:25 pm
supra wrote:Thanks!
You could have learned how to read codes. I was only reducing codes instead of big codes. I had to do tips and tricks or mastering. :D :D That why i can saved file sizes.
If I could understand what you are saying I could give a comment, as it seems gibberish
Especially as these comments are a YEAR later
Return to “Python”
