Trying to make sense of following code
Posted: Mon Mar 10, 2014 7:33 pm
https://code.google.com/p/webiopi/sourc ... _init__.py
Last line, self._getPascal__() which is defined as
def __getPascal__(self):
raise NotImplementedError
There's nothing inside the _getPascal__ function. There's real stuff inside. Is this right?
class Pressure():
def __init__(self, altitude=0, external=None):
self.altitude = toint(altitude)
if isinstance(external, str):
self.external = deviceInstance(external)
else:
self.external = external
if self.external != None and not isinstance(self.external, Temperature):
raise Exception("external must be a Temperature sensor")
def __family__(self):
return "Pressure"
def __getPascalAtSea__(self):
@request("GET", "sensor/pressure/pa")
@response("%d")
def getPascal(self):
return self.__getPascal__()Last line, self._getPascal__() which is defined as
