Bus.py for WebIOPi
Posted: Sun Mar 09, 2014 3:11 am
FUNCTIONS = {
"I2C": {"enabled": False, "gpio": {0:"SDA", 1:"SCL", 2:"SDA", 3:"SCL"}, "modules": ["i2c-bcm2708", "i2c-dev"]},
"SPI": {"enabled": False, "gpio": {7:"CE1", 8:"CE0", 9:"MISO", 10:"MOSI", 11:"SCLK"}, "modules": ["spi-bcm2708", "spidev"]},
"UART": {"enabled": False, "gpio": {14:"TX", 15:"RX"}},
"ONEWIRE": {"enabled": False, "gpio": {4:"DATA"}, "modules": ["w1-gpio"], "wait": 2}
def loadModule(module):
debug("Loading module : %s" % module)
subprocess.call(["modprobe", module])
def unloadModule(module):
subprocess.call(["modprobe", "-r", module])
def loadModules(bus):
if FUNCTIONS[bus]["enabled"] == False and not modulesLoaded(bus):
info("Loading %s modules" % bus)
for module in FUNCTIONS[bus]["modules"]:
loadModule(module)
if "wait" in FUNCTIONS[bus]:
info("Sleeping %ds to let %s modules load" % (FUNCTIONS[bus]["wait"], bus))
time.sleep(FUNCTIONS[bus]["wait"])
FUNCTIONS[bus]["enabled"] = True
def unloadModules(bus):
info("Unloading %s modules" % bus)
FUNCTIONS[bus]["enabled"] = False
def __modulesLoaded__(modules, lines):
if len(modules) == 0:
return True
for line in lines:
if modules[0].replace("-", "_") == line.split(" ")[0]:
return __modulesLoaded__(modules[1:], lines)
return False
def modulesLoaded(bus):
if not bus in FUNCTIONS or not "modules" in FUNCTIONS[bus]:
return True
f = open("/proc/modules")
c = f.read()
f.close()
lines = c.split("\n")
return __modulesLoaded__(FUNCTIONS[bus]["modules"], lines)
def checkAllBus():
for bus in FUNCTIONS:
if modulesLoaded(bus):
class Bus():
def __init__(self, busName, device, flag=os.O_RDWR):
loadModules(busName)
self.busName = busName
self.device = device
self.flag = flag
self.fd = 0
self.open()
def __str__(self):
return "Bus(%s, %s)" % (self.busName, self.device)
def open(self):
self.fd = os.open(self.device, self.flag)
if self.fd < 0:
raise Exception("Cannot open %s" % self.device)
def close(self):
if self.fd > 0:
os.close(self.fd)
def available(self):
raise NotImplementedError
def read(self, size=1):
if self.fd > 0:
return os.read(self.fd, size)
raise Exception("Device %s not open" % self.device)
def readBytes(self, size=1):
return bytearray(self.read(size))
def readByte(self):
return self.readBytes()[0]
def write(self, string):
if self.fd > 0:
return os.write(self.fd, string)
def writeBytes(self, data):
return self.write(bytearray(data))
def writeByte(self, value):
self.writeBytes([value])1)What's this function does?
return True
for line in lines:
return False
2)and what's modulesLoaded?
return True
c = f.read()
f.close()
3)what's the definition of bus ? I don't see instantiation of Bus class
def checkAllBus():
