HELP! I need Python to ignore this little error!
Posted: Sun Mar 02, 2014 1:38 pm
Hello all,
I am using a Python library called cwiid in order to get data from a Wiimote and I want to make it into a tutorial! I have just coded a fairly big program that also gets accelerometer data from the Wiimote... It all works however periodically through the program I get warnings that say this:
They do not affect the program but I think that they do not look pretty and I can't be doing a tutorial with them in!
How on earth do I get Python to ignore them?!
Here is my program:
Thanks,
The Raspberry Pi Guy
Received unexpected write report
Here is my program:
This program utilises the cwiid Python library in order to get input over bluetooth from a wiimote.
# The following lines of code demonstrate many of the features realted to wiimotes, such as capturing button presses and rumbling the controller.
# Whilst cwiid does have support for accelerometer data, it is not very well documented and thus hard to implement efficiently!
# Coded by The Raspberry Pi Guy. Work based on some of Matt Hawkin's!
import cwiid, time
button_delay = 0.1
print 'Please press buttons 1 + 2 on your Wiimote now ...'
time.sleep(1)
# This code attempts to connect to your Wiimote and if it fails the program quits
try:
wii=cwiid.Wiimote()
except RuntimeError:
print "Cannot connect to your Wiimote. Run again and make sure you are holding buttons 1 + 2!"
quit()
print 'Wiimote connection established!\n'
print 'Go ahead and press some buttons\n'
print 'Press PLUS and MINUS together to disconnect and quit.\n'
wii.rpt_mode = cwiid.RPT_BTN
while True:
buttons = wii.state['buttons']
# Detects whether + and - are held down and if they are it quits the program
if (buttons - cwiid.BTN_PLUS - cwiid.BTN_MINUS == 0):
print '\nClosing connection ...'
# NOTE: This is how you RUMBLE the Wiimote
wii.rumble = 1
time.sleep(1)
wii.rumble = 0
exit(wii)
# The following code detects whether any of the Wiimotes buttons have been pressed and then prints a statement to the screen!
if (buttons & cwiid.BTN_LEFT):
print 'Left pressed'
time.sleep(button_delay)
if(buttons & cwiid.BTN_RIGHT):
print 'Right pressed'
if (buttons & cwiid.BTN_UP):
print 'Up pressed'
if (buttons & cwiid.BTN_DOWN):
print 'Down pressed'
if (buttons & cwiid.BTN_1):
print 'Button 1 pressed'
if (buttons & cwiid.BTN_2):
print 'Button 2 pressed'
if (buttons & cwiid.BTN_A):
print 'Button A pressed'
if (buttons & cwiid.BTN_B):
print 'Button B pressed'
if (buttons & cwiid.BTN_HOME):
wii.rpt_mode = cwiid.RPT_BTN | cwiid.RPT_ACC
check = 0
while check == 0:
print(wii.state['acc'])
time.sleep(0.01)
check = (buttons & cwiid.BTN_HOME)
if (buttons & cwiid.BTN_MINUS):
print 'Minus Button pressed'
if (buttons & cwiid.BTN_PLUS):
print 'Plus Button pressed'
