dqpi
tornado send
Mon Feb 17, 2014 4:43 pm
I found this sourcecode online for connecting with a webpage.
http://niltoid.com/blog/raspberry-pi-arduino-tornado/
That works fine but I have a while loop running in another file that outputs values. I want to send these values to the webpage (self.write_message). So my question is: I want to call the write_message from another file. I am not advanced in Python. How can I do this?
import tornado.httpserver
import tornado.ioloop
import tornado.options
import tornado.web
import tornado.websocket
from tornado.options import define, options
define("port", default=8080, help="run on the given port", type=int)
class IndexHandler(tornado.web.RequestHandler):
def get(self):
self.render('index.html')
class WebSocketHandler(tornado.websocket.WebSocketHandler):
def open(self):
print 'new connection'
self.write_message("connected")
def on_message(self, message):
print 'message received %s' % message
self.write_message('message received %s' % message)
def writemessage():
self.write_message('test')
def on_close(self):
print 'connection closed'
if __name__ == "__main__":
tornado.options.parse_command_line()
app = tornado.web.Application(
handlers=[
(r"/", IndexHandler),
(r"/ws", WebSocketHandler)
httpServer = tornado.httpserver.HTTPServer(app)
httpServer.listen(options.port)
print "Listening on port:", options.port
tornado.ioloop.IOLoop.instance().start()
Feej
Re: tornado send
Sun Mar 09, 2014 1:54 pm
When you say you have a while loop running another file, what exactly does that mean? In another Python application?
Return to “Python”
