resist10k
Loop Interrupt
Wed Jan 22, 2014 6:37 am
Hello All Im pretty new to programming and im running into an issue. Ive been looking around everywhere but i cant seem to figure out how to get my program to work. I have a PWM for loop running to fade an LED. Id like to get user input from keyboard to stop the PWM loop.I cant use raw_input because that will stop the loop. Is there an EASY way to get a key press while a for loop is running? ive tried pygame but i cant seem to get it tor work. Everything i try seems to need to be out of a loop to run. Im trying to run this all from a ssh shell so it wont have any windows or anything. The workaround ive been doing is to launch another terminal and run a seperate python script with just the loop there which works but id like it a bit more neat. Again im pretty new to programming i was looking into threading but couldnt quite figure it out. Any suggestions will help thanks :)
AndyD
Re: Loop Interrupt
Wed Jan 22, 2014 7:20 am
This thread is has some suggestions.
resist10k
Re: Loop Interrupt
Fri Jan 24, 2014 9:02 pm
So ive tried curses and a couple other libraries and im still stuck. It seems that most libraries stop execution of the loop and wait for input so i cant have my PWM continue until key press. Pygame dosent look like its for command line programs. So im still kinda lost :(
AndyD
Re: Loop Interrupt
Fri Jan 24, 2014 9:33 pm
Did you look at this. You need to specifically tell curses not to wait for input.
damn.nodelay(1) # doesn't keep waiting for a key press
resist10k
Re: Loop Interrupt
Fri Jan 24, 2014 9:53 pm
lol sorry was rushing around trying snippets of code and i didnt see that one just looked at the post where he said it didnt work. Tried it myself and it looks like its running Thx Andy :)
Return to “Python”
