Error Logging - Help
Posted: Sun Jan 19, 2014 7:57 am
by robbo100
I have just finished writing some code in Python which is designed to run on my RPi without a monitor connected. I expect to need to keep the RPi running this script for upto 60 days.
When I run it via SSH, everything works fine, but now that I have set the code to run at boot-up, I have discovered that it is crashing after 10 hours or so.
Is there any command that I can use, which will log ANY error for the whole script (any def or thread) so that I can track the problem down?
Robbo100.
Re: Error Logging - Help
Posted: Sun Jan 19, 2014 8:50 am
by ZacharyIgielman
robbo100 wrote:I have just finished writing some code in Python which is designed to run on my RPi without a monitor connected. I expect to need to keep the RPi running this script for upto 60 days.
Robbo100.
try:
    #your code
except Exception,e:
    print str(e)
Posted: Sun Jan 19, 2014 9:52 am
by robbo100
Presumably I can use the "print >>" command to send the string to an open file?
Posted: Sun Jan 19, 2014 10:25 am
by ZacharyIgielman
robbo100 wrote:Presumably I can use the "print >>" command to send the string to an open file?
Yes you can!
If you want the whole traceback:
import traceback
try:
    #code
except Exception, e:
    print str(e) #you could also print to file here
    traceback.print_exc()
Posted: Sun Jan 19, 2014 10:41 am
by robbo100
Thanks mate
Posted: Sun Jan 19, 2014 12:57 pm
by elParaguayo
If I've got a script I leave running, I either use the logging module as I can set various debug levels, or do something simple like this:
from datetime import datetime
def scriptdebug(errormessage):
    with open("error.log", "a") as errorlog:
        errorlog.write("%s\t%s\n" % (datetime.strftime(datetime.now(),
                                     "%d-%m-%y %H:%M"),
                                     errormessage))
You can then use it as Zachary suggests:
try:
    #code
    scriptdebug(e)
Error messages will be posted to the "error.log" file with a timestamp of the current date and time.
EDIT: Should also add that if you want to use this method in conjunction with the traceback module as Zachary suggested (and the advantage of this is that you do get more detail on the error) then, assuming you've imported the traceback module, you'd call the scriptdebug method like this:
scriptdebug(traceback.format_exc())
