Simple gpio alarm script
Posted: Sat Jan 04, 2014 3:11 am
by kawa_j
i am looking for a simple alarm script that wil detect if a gpio is switched from high to low and then send an email
have tried the privatepiproject(and allot of other scripts) but they are not working properly
also tried to write it myself but i am not good at python coding :mrgreen:
can someone please help me?
greets
kawa
Re: Simple gpio alarm script
Posted: Sat Jan 04, 2014 6:59 pm
by TrevorAppleton
I recommend this resource to learn how to use the GPIO in Python. It really is very good.
http://raspi.tv/2013/how-to-use-interru ... d-rpi-gpio
Enjoy!
Posted: Sun Jan 05, 2014 3:28 am
by kawa_j
Thanks for the response,
tried to make the script myself but i suck!
i get this error when i run the script:
File "alarm.py", line 29
server.ehlo()
IndentationError: unexpected indent
here is the script :
#!/usr/bin/env python2.7
# script by Alex Eames http://RasPi.tv/
# http://raspi.tv/2013/how-to-use-interru ... d-rpi-gpio
import smtplib
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
server = smtplib.SMTP('smtp.gmail.com:587')
gmail_user = "sender@gmail.com"
gmail_pwd = "******"
FROM = 'from@gmail.com'
TO = ['to@gmail.com'] #must be a list
SUBJECT = "Testing sending using gmail"
TEXT = "Testing sending mail using gmail servers"
# Prepare actual message
message = """\From: %s\nTo: %s\nSubject: %s\n\n%s
""" % (FROM, ", ".join(TO), SUBJECT, TEXT)
# GPIO 23 set up as input. It is pulled up to stop false signals
GPIO.setup(23, GPIO.IN, pull_up_down=GPIO.PUD_UP)
try:
GPIO.wait_for_edge(23, GPIO.RISING)
print "\nalarm rising signal"
server.ehlo()
server.starttls()
server.login(gmail_user, gmail_pwd)
server.sendmail(FROM, TO, message)
#server.quit()
server.close()
print 'successfully sent the mail'
except:
print "failed to send mail"
except KeyboardInterrupt:
GPIO.cleanup() # clean up GPIO on CTRL+C exit
GPIO.cleanup() # clean up GPIO on normal exit
What is going wrong?
greets kawa
Posted: Sun Jan 05, 2014 4:16 am
by Richard-TX
python, unlike many languages, requires indents in certain places.
while and for loops must be indented.
Posted: Tue Jan 07, 2014 2:17 am
by kawa_j
Script is up and running! But stil have one problem :cry:
For some reason the script/Pi detects a rising signal (when the script is running for 4min)?
The gpio input has a 1K Ohm resistor so it is not floating
What is going wrong? Can someone please help :roll:
Here is the script:
import smtplib
import time
def sendemail(from_addr, to_addr_list, cc_addr_list,
subject, message,
login, password,
smtpserver='smtp.gmail.com:587'):
header = 'From: %s\n' % from_addr
header += 'To: %s\n' % ','.join(to_addr_list)
header += 'Cc: %s\n' % ','.join(cc_addr_list)
header += 'Subject: %s\n\n' % subject
message = header + message
server = smtplib.SMTP(smtpserver)
server.starttls()
server.login(login,password)
problems = server.sendmail(from_addr, to_addr_list, message)
server.quit()
GPIO.setup(23, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(24, GPIO.OUT, initial=False) #Siren pin setup
try:
print "\nRising edge ALARM"
sendemail(from_addr = '@gmail.com',
to_addr_list = ['@gmail.coml'],
cc_addr_list = [''],
subject = 'ALARM',
message = 'alarm',
login = '@gmail.com',
password = '****')
GPIO.output(24, True)
time.sleep(5)
