http://www.maxbotix.com/Ultrasonic_Sensors/MB7040.htm
They have a sample arduino wire library to use this sensor:
Arduino I2C Code Example for I2CXL-MaxSonar Products
Development System - Arduino Uno (as of Arduino 1.0.1)
Develop. Board: Arduino Uno R3
/* Code for Arduino Uno R3
Assumes the sensor is using the default address
Sensor Connections:
Pin 7 to GND
Pin 6 to 5V
Pin 5 to SCL
Pin 4 to SDA
Requires pull‑ups for SCL and SDA connected to 5V to work reliably
#include "Wire.h"
//The Arduino Wire library uses the 7-bit version of the address, so the code example uses 0x70 instead of the 8‑bit 0xE0
#define SensorAddress byte(0x70)
//The Sensor ranging command has a value of 0x51
#define RangeCommand byte(0x51)
//These are the two commands that need to be sent in sequence to change the sensor address
#define ChangeAddressCommand1 byte(0xAA)
#define ChangeAddressCommand2 byte(0xA5)
void setup() {
Serial.begin(9600);//Open serial connection at 9600 baud
Wire.begin();//Initiate Wire library for I2C communications with I2CXL‑MaxSonar‑EZ
void loop() {
takeRangeReading(); //Tell the sensor to perform a ranging cycle
delay(100); //Wait for the sensor to finish
word range = requestRange(); //Get the range from the sensor
Serial.print("Range:");Serial.println(range); //Print to the user
//Commands the sensor to take a range reading
void takeRangeReading(){
Wire.beginTransmission(SensorAddress); //Start addressing
Wire.write(RangeCommand); //send range command
Wire.endTransmission(); //Stop and do something else now
//Returns the last range that the sensor determined in its last ranging cycle in centimeters. Returns 0 if there is no communication.
word requestRange(){
Wire.requestFrom(SensorAddress, byte(2));
if(Wire.available() >= 2){ //Sensor responded with the two bytes
byte HighByte = Wire.read(); //Read the high byte back
byte LowByte = Wire.read(); //Read the low byte back
word range = word(HighByte, LowByte); //Make a 16-bit word out of the two bytes for the range
return range;
else {
return word(0); //Else nothing was received, return 0
/* Commands a sensor at oldAddress to change its address to newAddress
oldAddress must be the 7-bit form of the address that is used by Wire
7BitHuh determines whether newAddress is given as the new 7 bit version or the 8 bit version of the address
\ If true, if is the 7 bit version, if false, it is the 8 bit version
void changeAddress(byte oldAddress, byte newAddress, boolean SevenBitHuh){
Wire.beginTransmission(oldAddress); //Begin addressing
Wire.write(ChangeAddressCommand1); //Send first change address command
Wire.write(ChangeAddressCommand2); //Send second change address command
byte temp;
if(SevenBitHuh){ temp = newAddress << 1; } //The new address must be written to the sensor
else { temp = newAddress; } //in the 8bit form, so this handles automatic shifting
Wire.write(temp); //Send the new address to change to
As a minor note, in old Arduino IDE's
Wire.read() should be substituted by Wire.receive()
and
Wire.write() should be substituted by Wire.send()
As of now, i ear the sensor taking a reading, but i can not read back any value from the sensor.
Here is what i got so far, a little help would be really appreciated!
#!/usr/bin/python
import time
import smbus
bus = smbus.SMBus(1)
addr = 0x70
try:
bus.write_byte(addr, 0x51)
except IOError, err:
print err
time.sleep(1)
try:
HighByte = bus.read_byte(addr)
LowByte = bus.read_byte(addr)
print err
print HighByte
print LowByte
