freely
Tkinter display error
Mon Aug 12, 2013 1:11 am
Hi
I am experimenting with Tkinter and wanted to try it on the pi - but when I try the acid test - window=Tkinter.Tk() - I get the error:
_tkinter.TclError: no display name and no $DISPLAY environment variable
I saw another post on a similar issue on this board but it was well down the thread and wasn't resolved - so I hoped to push it back up the list a bit (!) and see if anyone can help me figure out what's going wrong.
I'm running Python 2.7 from the command line (sudo python). startx runs normally if I try to use the GUI.
any suggestions gratefully received!
freely
dr_d_gee
Re: Tkinter display error
Tue Aug 13, 2013 1:39 pm
A Tkinter program will need the GUI to run. Have you tried running it under X?
freely
Thu Aug 15, 2013 2:24 am
Hi - ah! I didn't realise this. So I have to run a GUI in order to create a Tkinter GUI? Is that always true for Linux?
Sorry to be so ignorant! I have been experimenting from a Windows command prompt - but I use the pi without a mouse so haven't even explored X except to make sure it ran. Having started X, can I get to a terminal window without the mouse?
Thanks again!
Freely
Return to “Python”
