Just thought I'd pop in and post where I'm at for the SCADA system I've built for my home through python accessing the GPIOs of the RPI using one wire and I2C buses. I will eventually be adding other buses into the system and am just wondering what every one thinks of the interface.
So attached is a screen shot of the interface, which controls lights and heating for the moment, and also includes a real-time clock that I built using the ds1339 AU+ chip.
Feel free to criticize and or add comments to make things better. I'm currently working on a new board that will integrate all of the components on one board as currently it is multiple boards which makes it a little sloppy in my opinion!
Home-SCADA system
- Attachments
- scada-home.png (18.88 KiB) Viewed 4025 times
Re: Home-SCADA system
nice
What SCADA software did you use for your user interface? or did you just write the interface yourself?
Tony
Tony, I wrote the software myself, as stated all written in python 3.3. Now I am using the one wire driver for one wire and the I2C drivers native to the RPI.
The temperatures displayed are the actual temperatures at my home at the time of the snap shot.
I do have other devices I want to add into the system but I have yet to build and test them such as humidity, automatic rainfall gage, etc, I'm also going to be logging all the weather related data for historical purposes including the inside temp. Then after all that possibly graphing said data and using it to compare power and heating usage. Of course much of that will be later as my work bench is quit full with components for this project.
So far the hardware part of this project is the RPI, a customized IO board(with GPIO pin circuit protection), 5 relays, 2 DS18S20 temp sensors and 1 DS1339AU+ real time clock.
I did quit a bit of SCADA programing in vb as well before I retired but none of that is used here.
care to share your GUI code?
could you share your GUI code?
Hello ,i'm trynig to develop my SCADA system too, and i'm under pressure i have only two months to do it.
Can you please detail me the steps to follow to develop such system,technologies to use, protocols.
I will be grateful if you could help me.
Thanks in advance.
Thanks in advance.
mikegottwald, sorry for the delay. I used the QT Designer to create the interface but here's the code anyway.
I do all my designing on my x86-64 machine and then transfer it to my pi. I also have the QT Designer on my pi just in case. I also have KDE fully loaded on my pi to for some of the icons and other things that maybe needed.
If you have any questions feel free to ask.
Enjoy.
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0">
<class>Dialog</class>
<widget class="QDialog" name="Dialog">
<property name="geometry">
<rect>
<x>0</x>
<y>0</y>
<width>492</width>
<height>302</height>
</rect>
</property>
<property name="windowTitle">
<string>Set Automation</string>
</property>
<property name="windowIcon">
<iconset>
<normaloff>../../../usr/share/icons/hicolor/22x22/actions/catalogmanager.png</normaloff>../../../usr/share/icons/hicolor/22x22/actions/catalogmanager.png</iconset>
</property>
<widget class="QFrame" name="frame">
<rect>
<x>10</x>
<y>10</y>
<width>231</width>
<height>121</height>
</rect>
</property>
<property name="frameShape">
<enum>QFrame::StyledPanel</enum>
</property>
<property name="frameShadow">
<enum>QFrame::Raised</enum>
</property>
<widget class="QLabel" name="label_3">
<rect>
<x>10</x>
<y>10</y>
<width>101</width>
<height>16</height>
</rect>
</property>
<property name="font">
<font>
<pointsize>10</pointsize>
</font>
</property>
<property name="text">
<string>Outside Lights</string>
</property>
<property name="textFormat">
<enum>Qt::RichText</enum>
</property>
</widget>
<widget class="KLed" name="led3">
<rect>
<x>160</x>
<y>80</y>
<width>21</width>
<height>21</height>
</rect>
</property>
<property name="state">
<enum>KLed::Off</enum>
</property>
</widget>
<widget class="QPushButton" name="btnFlood">
<rect>
<x>10</x>
<y>40</y>
<width>99</width>
<height>23</height>
</rect>
</property>
<string>Flood Light</string>
</property>
</widget>
<widget class="KLed" name="led1">
<property name="enabled">
<bool>true</bool>
</property>
<rect>
<x>160</x>
<y>40</y>
<width>21</width>
<height>21</height>
</rect>
</property>
</property>
</widget>
<widget class="KLed" name="led2">
<rect>
<x>200</x>
<y>40</y>
<width>21</width>
<height>21</height>
</rect>
</property>
<enum>KLed::On</enum>
</property>
<property name="color">
<color>
<red>255</red>
<green>0</green>
<blue>0</blue>
</color>
</property>
</widget>
<widget class="QPushButton" name="btnPorch">
<rect>
<x>10</x>
<y>80</y>
<width>99</width>
<height>23</height>
</rect>
</property>
<string>Porch Light</string>
</property>
</widget>
<widget class="KLed" name="led4">
<rect>
<x>200</x>
<y>80</y>
<width>21</width>
<height>21</height>
</rect>
</property>
</property>
<color>
<red>255</red>
<green>0</green>
<blue>0</blue>
</color>
</property>
</widget>
</widget>
<widget class="QFrame" name="frame_2">
<rect>
<x>250</x>
<y>10</y>
<width>231</width>
</rect>
</property>
</property>
</property>
<widget class="QLabel" name="label_4">
<rect>
<x>10</x>
<y>10</y>
<width>91</width>
<height>16</height>
</rect>
</property>
<font>
</font>
</property>
<string>Inside Lights</string>
</property>
</widget>
<widget class="KLed" name="led6">
<rect>
<x>200</x>
<y>40</y>
<width>21</width>
<height>21</height>
</rect>
</property>
</property>
<color>
<red>255</red>
<green>0</green>
<blue>0</blue>
</color>
</property>
</widget>
<widget class="KLed" name="led8">
<rect>
<x>200</x>
<y>80</y>
<width>21</width>
<height>21</height>
</rect>
</property>
</property>
<color>
<red>255</red>
<green>0</green>
<blue>0</blue>
</color>
</property>
</widget>
<widget class="KLed" name="led5">
<rect>
<x>160</x>
<y>40</y>
<width>21</width>
<height>21</height>
</rect>
</property>
</property>
</widget>
<widget class="QPushButton" name="btnLiving">
<rect>
<x>10</x>
<y>80</y>
<width>121</width>
<height>23</height>
</rect>
</property>
<string>Living room Light</string>
</property>
</widget>
<widget class="QPushButton" name="btnGame">
<rect>
<x>10</x>
<y>40</y>
<width>121</width>
<height>23</height>
</rect>
</property>
<string>Game room Light</string>
</property>
</widget>
<widget class="KLed" name="led7">
<rect>
<x>160</x>
<y>80</y>
<width>21</width>
<height>21</height>
</rect>
</property>
</property>
</widget>
</widget>
<widget class="QFrame" name="frame_3">
<rect>
<x>10</x>
<y>140</y>
<width>471</width>
<height>151</height>
</rect>
</property>
</property>
</property>
<widget class="QLabel" name="label_2">
<rect>
<x>15</x>
<y>73</y>
<width>111</width>
<height>16</height>
</rect>
</property>
<string>Set Temperature</string>
</property>
</widget>
<widget class="QDoubleSpinBox" name="doubleSpinBox">
<rect>
<x>160</x>
<y>70</y>
<width>62</width>
<height>22</height>
</rect>
</property>
<property name="minimum">
<double>45.000000000000000</double>
</property>
<property name="maximum">
<double>75.000000000000000</double>
</property>
</widget>
<widget class="QLabel" name="label">
<rect>
<x>15</x>
<y>38</y>
<width>141</width>
<height>16</height>
</rect>
</property>
<string>Inside Temperature</string>
</property>
<property name="scaledContents">
<bool>true</bool>
</property>
</widget>
<widget class="QLCDNumber" name="lcdTempIn">
<rect>
<x>160</x>
<y>30</y>
<width>64</width>
<height>30</height>
</rect>
</property>
<property name="segmentStyle">
<enum>QLCDNumber::Flat</enum>
</property>
</widget>
<widget class="QLabel" name="label_5">
<rect>
<x>10</x>
<y>10</y>
<width>111</width>
<height>16</height>
</rect>
</property>
<font>
</font>
</property>
<string>Temperatures</string>
</property>
</widget>
<widget class="QLabel" name="label_6">
<rect>
<x>250</x>
<y>38</y>
<width>141</width>
<height>16</height>
</rect>
</property>
<string>Outside Temperature</string>
</property>
</widget>
<widget class="QLCDNumber" name="lcdTempOut">
<rect>
<x>390</x>
<y>30</y>
<width>64</width>
<height>30</height>
</rect>
</property>
</property>
</widget>
<widget class="QPushButton" name="btnExit">
<rect>
<x>240</x>
<y>110</y>
<width>221</width>
<height>23</height>
</rect>
</property>
<string>&Exit</string>
</property>
</widget>
<widget class="KLed" name="led9">
<rect>
<x>160</x>
<y>110</y>
<width>21</width>
<height>21</height>
</rect>
</property>
</property>
</widget>
<widget class="QPushButton" name="btnHeat">
<rect>
<x>10</x>
<y>110</y>
<width>99</width>
<height>23</height>
</rect>
</property>
<string>Heat</string>
</property>
</widget>
<widget class="KLed" name="led10">
<rect>
<x>200</x>
<y>110</y>
<width>21</width>
<height>21</height>
</rect>
</property>
</property>
<color>
<red>255</red>
<green>0</green>
<blue>0</blue>
</color>
</property>
</widget>
<widget class="QLabel" name="label_7">
<rect>
<x>250</x>
<y>73</y>
<width>111</width>
<height>16</height>
</rect>
</property>
<string>Last Updated @</string>
</property>
</widget>
<widget class="QLabel" name="lblLastUpDate">
<rect>
<x>360</x>
<y>73</y>
<width>90</width>
<height>14</height>
</rect>
</property>
<string/>
</property>
</widget>
</widget>
<zorder>frame_3</zorder>
<zorder>frame</zorder>
<zorder>frame_2</zorder>
</widget>
<customwidgets>
<customwidget>
<class>KLed</class>
<extends>QWidget</extends>
<header>kled.h</header>
</customwidget>
</customwidgets>
<tabstops>
<tabstop>btnFlood</tabstop>
<tabstop>btnPorch</tabstop>
<tabstop>btnGame</tabstop>
<tabstop>btnLiving</tabstop>
<tabstop>doubleSpinBox</tabstop>
<tabstop>btnHeat</tabstop>
<tabstop>btnExit</tabstop>
</tabstops>
<resources/>
<connections>
<connection>
<sender>btnExit</sender>
<signal>clicked()</signal>
<receiver>Dialog</receiver>
<slot>close()</slot>
<hints>
<hint type="sourcelabel">
<x>360</x>
<y>257</y>
</hint>
<hint type="destinationlabel">
<x>245</x>
<y>150</y>
</hint>
</hints>
</connection>
<connection>
<sender>btnFlood</sender>
<receiver>led1</receiver>
<slot>on()</slot>
<hints>
<x>99</x>
<y>51</y>
</hint>
<x>180</x>
<y>60</y>
</hint>
</hints>
</connection>
<connection>
<sender>btnPorch</sender>
<receiver>led3</receiver>
<slot>on()</slot>
<hints>
<x>69</x>
<y>101</y>
</hint>
<x>180</x>
<y>100</y>
</hint>
</hints>
</connection>
<connection>
<sender>btnGame</sender>
<receiver>led5</receiver>
<slot>on()</slot>
<hints>
<x>320</x>
<y>61</y>
</hint>
<x>420</x>
<y>60</y>
</hint>
</hints>
</connection>
<connection>
<sender>btnLiving</sender>
<receiver>led7</receiver>
<slot>on()</slot>
<hints>
<x>320</x>
<y>101</y>
</hint>
<x>420</x>
<y>100</y>
</hint>
</hints>
</connection>
<connection>
<sender>btnHeat</sender>
<receiver>led9</receiver>
<slot>on()</slot>
<hints>
<x>69</x>
<y>261</y>
</hint>
<x>180</x>
<y>260</y>
</hint>
</hints>
</connection>
</connections>
</ui>
Enjoy.
bou_ih
It all depends on what you're attempting to do and with what hardware. There are so many different aspects to SCADA programming that without knowing the specifics it would be impossible to give you any advise at all. So please more detail.
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Have you looked at MQTT. That's an excellent protocol for connecting SCADA devices to a centralised broker which can publish that data on easy to subscribe topics. That means you can easily separate the presentation layer from the data collection layer.
It was invented by Dr Andy Stanford-Clark the IBM'er who wired his house so that it tweets. He has complete control from anywhere in the world. MQTT is becoming the protocol of choice for the "Internet of Things".
http://mqtt.org
http://mosquitto.org
Mosquitto runs on my RPi.
Here's the project I wrote this weekend using python & MQTT
https://www.ibm.com/developerworks/comm ... x_and_gpio
http://mqtt.org
