replay game pygame and raspberry snake
Posted: Thu Jul 18, 2013 2:03 pm
by apples723
Ok so i got the book that teaches you the game raspberry snake and i wrote and add some of my own twist(you can see it in the code). but now i want to add one more twist i want to add the option to have a pop up come up and ask if they want to play again if someone could point me in the right direction that would be great. heres my current code:
import pygame, sys, time, random
from pygame.locals import *
import easygui as eg
pygame.init()
eg.msgbox("""
Game starts fast!
Get your hands on the arrorw keys and hit enter to start!
Press ESC to quit the game.
fpsClock = pygame.time.Clock()
playSurface = pygame.display.set_mode((640, 480))
pygame.display.set_caption('Raspberry Snake')
redColour = pygame.Color(255, 0, 0)
blackColour = pygame.Color(0, 0, 0)
whiteColour = pygame.Color(255, 255, 255)
greyColour = pygame.Color(150, 150, 150)
snakePosition = [100,100]
snakeSegments = [[100,100],[80,100],[60,100]]
raspberryPosition = [300,300]
raspberrySpawned = 1
direction = 'right'
changeDirection = direction
def gameOver():
    gameOverFont = pygame.font.Font('freesansbold.ttf', 72)
    gameOverSurf = gameOverFont.render('Game Over', True, greyColour)
    gameOverRect = gameOverSurf.get_rect()
    gameOverRect.midtop = (320, 10)
    playSurface.blit(gameOverSurf, gameOverRect)
    pygame.display.flip()
    time.sleep(5)
    pygame.quit()
    sys.exit()
while True:
    for event in pygame.event.get():
        if event.type == QUIT:
            pygame.quit()
        elif event.type == KEYDOWN:
            if event.key == K_RIGHT or event.key == ord('d'):
                changeDirection = 'right'
            if event.key == K_LEFT or event.key == ord('a'):
                changeDirection = 'left'
            if event.key == K_UP or event.key == ord('w'):
                changeDirection = 'up'
            if event.key == K_DOWN or event.key == ord('s'):
                changeDirection = 'down'
            if event.key == K_ESCAPE:
                pygame.event.post(pygame.event.Event(QUIT))
    if changeDirection == 'right' and not direction == 'left':
        direction = changeDirection
    if changeDirection == 'left' and not direction == 'right':
    if changeDirection == 'up' and not direction == 'down':
    if changeDirection == 'down' and not direction == 'up':
    if direction == 'right':
        snakePosition[0] += 20
    if direction == 'left':
        snakePosition[0] -= 20
    if direction == 'up':
        snakePosition[1] -= 20
    if direction == 'down':
        snakePosition[1] += 20
    snakeSegments.insert(0,list(snakePosition))
    if snakePosition[0] == raspberryPosition[0] and snakePosition[1] == raspberryPosition[1]:
        raspberrySpawned = 0
    else:
        snakeSegments.pop()
    if raspberrySpawned == 0:
        x = random.randrange(1,32)
        y = random.randrange(1,24)
        raspberryPosition = [int(x*20),int(y*20)]
    playSurface.fill(blackColour)
    for position in snakeSegments:
        pygame.draw.rect(playSurface,whiteColour,Rect(position[0], position[1], 20, 20))
    pygame.draw.rect(playSurface,redColour,Rect(raspberryPosition[0], raspberryPosition[1], 20, 20))
    if snakePosition[0] > 620 or snakePosition[0] < 0:
        gameOver()
    if snakePosition[1] > 460 or snakePosition[1] < 0:
        gameOver()
    for snakeBody in snakeSegments[1:]:
        if snakePosition[0] == snakeBody[0] and snakePosition[1] == snakeBody[1]:
            gameOver()
    fpsClock.tick(30)
Re: replay game pygame and raspberry snake
Posted: Thu Jul 18, 2013 5:16 pm
by davef21370
Change your gameOver() function to read something like this (I haven't tested this but it can't be far off). When this function is called from your main loop, if the player hits Y or y it will return to your main loop, if so reset your snake and carry on.
Dave.
(Not sure the K_Y and K_N bits are correct but you get the gist.)
def gameOver():
    gameOverSurf = gameOverFont.render('Game Over - Play Again? (Y/N)', True, greyColour)
    while True:
                pygame.quit()
                if event.key == K_Y or event.key == K_y:
                   return
                if event.key == K_N or event.key == K_n:
                   break
    pygame.quit()
    sys.exit()
Posted: Thu Jul 18, 2013 6:17 pm
by apples723
i get this error have tried multiple ways but when using any of them i get errors i tried yours and get this error
  File "C:\Python27\game2.py", line 111, in <module>
    gameOver()
  File "C:\Python27\game2.py", line 58, in gameOver
NameError: global name 'K_Y' is not defined
Posted: Thu Jul 18, 2013 8:00 pm
by davef21370
Just checked the docs, try getting rid of the K_Y bit and just using K_y, same for the N part, apparently PyGame doesn't distinguish between upper and lower case.
Dave.
Posted: Thu Jul 18, 2013 8:57 pm
by apples723
now it just doesnt do anything after i die no errors no nothing if you click yes the white worm moves like an inch but nothing else im running in idle does that matter?
Posted: Fri Jul 19, 2013 12:31 pm
by davef21370
You may need to re-initialise the snakePosition, snakeSegments, etc before returning from the yes/no part.
I'm not in a position to test anything until this Sunday but try anyway and keep us posted.
Dave.
Posted: Mon Jul 22, 2013 9:36 pm
by megazoic
Working with some high school kids at a summer 'funshop' in the US, we came up with this solution based on the above recommendations by previous replies to this question. It just involves adding to the gameOver() function.
def gameOver():
global snakePosition, snakeSegments, raspberryPosition, raspberrySpawned, direction, changeDirection
time.sleep(5)
gameOverSurf = gameOverFont.render('Play Another?', True, redColour)
gameOverRect.midtop = (320, 60)
while True:
			pygame.quit()
			#wait for key input
			if event.key == K_y:
				gameOverSurf = gameOverFont.render('Get Ready ;>()', True, greyColour)
				time.sleep(3)
				direction = 'right'
				return
			else:
				pygame.quit()
				sys.exit()
Posted: Mon Jul 22, 2013 11:05 pm
by apples723
megazoic wrote:Working with some high school kids at a summer 'funshop' in the US, we came up with this solution based on the above recommendations by previous replies to this question. It just involves adding to the gameOver() function.
def gameOver():
time.sleep(5)
while True:
			pygame.quit()
			#wait for key input
				time.sleep(3)
				direction = 'right'
				return
			else:
				pygame.quit()
				sys.exit()
did you test it because if i click y it just says get ready and doesnt do any thing here is my updated code
from subprocess import call
import pygame as pg
pygame.init()
eg.msgbox("""
Game starts fast!
screen = (500, 300)
direction = 'right'
def gameOver():
    gameOverFont = pygame.font.Font('freesansbold.ttf', 35)
    keys = pygame.key.get_pressed()
    while True:
             pygame.quit()
             #wait for key input
                time.sleep(3)
                direction = 'right'
                return
             else:
                pygame.quit()
                sys.exit()
while True:
                pygame.quit()
        else:
            snakeSegments.pop()
            gameOver()
            gameOver()
                gameOver()
        fpsClock.tick(30)
Posted: Tue Jul 23, 2013 5:37 pm
by megazoic
I am not a Python programmer and I have reformatted my pi's SD card for a different purpose so it will take a bit of time to get to the original configuration. I just tested the code I posted on my Mac and it works fine. I'm not sure about the extra code that you've added but noticed that you didn't include the 'global... ' at the beginning of the gameOver() def. Could it be that the variables that you are writing to inside the gameOver() are local and not the ones the game needs when returning from the gameOver() function (after responding with a 'y') to the main while loop?
Here's the code in it's entirety (mostly taken from the Users Guide)
#!/usr/bin/env python
# Raspberry Snake
# Written by Gareth Halfacree for the Raspberry Pi User Guide
pygame.init()
direction = 'right'
def gameOver():
	time.sleep(3)
	while True:
				pygame.quit()
				#wait for key input
					time.sleep(3)
					direction = 'right'
					return
				else:
					pygame.quit()
					sys.exit()
while True:
			pygame.quit()
	else:
		snakeSegments.pop()
		gameOver()
		gameOver()
			gameOver()
	fpsClock.tick(20)
Posted: Tue Jul 23, 2013 5:49 pm
by megazoic
Another note, I just noticed that the pygame.event may still retain a keypress from the previous game and this would trigger the pygame.guit() immediately when gameOver() is called. This happens when you press and hold a key past the call to gameOver(). An easy fix is to clear the event queue by calling pygame.event.get() right after time.sleep(3) in the above program.
