robbiwood
Programming the Adafruit 16x2 Character LCD + Keypad
Sun Jul 14, 2013 7:45 pm
Hi everyone,
I am having some major trouble with programming this board. I have it soldered right and set up right, but when I try to run my code http://pastebin.com/54w5Wa8T (or any test program), all I get is the backlight turning on and doing what its meant to do, but where text should be I see boxes! The top row is full of boxes, the bottom row is blank. How do I get my code working?
Thanks,
Robbi
joan
Re: Programming the Adafruit 16x2 Character LCD + Keypad
Sun Jul 14, 2013 9:02 pm
Perhaps the contrast is too low/high?
robbiwood
Sun Jul 14, 2013 9:18 pm
joan wrote:Perhaps the contrast is too low/high?
Well I'm not sure about that. It can turn nearly 360˚ only, is that normal? And when it is as far as it can go to the left, the boxes show up perfectly. But when I turn it all the way to the right, there are no boxes and just the background color.
Pantarhei
Mon Jul 15, 2013 7:48 pm
Yesterday I soldered my Adafruit 16x2 Character LCD + Keypad (Arduino version). I had the same issue, only boxes on the first row. I examined my work, I'm a noob on soldering, and did some resoldering. I reconnected the LCD and a shiny "Hello world" appeared. :P
You can also try this,
From the Adafruit website:
If you have a rev 2 (512MB) Pi, or if you're not getting anything displaying, it might be due to the I2C bus number change in the Pi hardware. Edit Adafruit_CharLCD.py using a command like "nano Adafruit_CharLCD.py" and change the line
lcd = Adafruit_CharLCDPlate(busnum = 0)
to
lcd = Adafruit_CharLCDPlate(busnum = 1)
robbiwood
Tue Jul 16, 2013 12:14 am
I just re-soldered the bottom, no result. I really hope there is something wrong with my code because i reaaaaaally don't want to re-solder the top. :P
robbiwood
Tue Jul 16, 2013 1:05 am
I re-soldered the top...
IT WORKS!!!!!!!! :D :D :D :D :D
Return to “Python”
