apples723
weather
Tue Jun 25, 2013 12:30 am
ok so heres my problem i want to write a script using module requests
my first problem is that request module is only recognised in idle but not in idle 3 and the problem with that is that my main script i want to use the weather script in is only working in idle 3
my second problem is that i get this error
  File "/home/pi/Desktop/Scripts/weather.py", line 9, in <module>
    print (forecast) ['forecast']['txt_forecast']
TypeError: 'instancemethod' object has no attribute '__getitem__'
when running this script
import requests
key = '015098ae0bc15cce'
ApiUrl = \
'http://api.wunderground.com/api/' + key + '/forecast/q/IA/Urbandale.json'
r = requests.get(ApiUrl)
forecast = r.json
print forecast ['forecast']['txt_forecast']
any help would be appreciated total noob here
Maddo
Re: weather
Tue Jun 25, 2013 6:31 am
Could you please link to module requests as I have no idea what it is meant to do, and no way of helping sorry.
apples723
Re: weather
Tue Jun 25, 2013 1:32 pm
Maddo wrote:Could you please link to module requests as I have no idea what it is meant to do, and no way of helping sorry.
does this help? http://www.python-requests.org/en/lates ... uickstart/
IanH2
Re: weather
Fri Jun 28, 2013 7:30 pm
I'm not familiar with the module, but the Python error suggests that 'forecast' ends up being a method of an object, which is something you need to call to get a usable result. Try something like:
forecast = r.json()
Ian
https://github.com/IanHarvey
addeswe
Re: weather
Mon Jul 22, 2013 9:16 am
Examplecode to get current degrees in C of my hometown Umeå, Sweden:
import requests
import json
apikey = "<insert api-key here>"
url = requests.get("http://api.wunderground.com/api/"+apikey+"/conditions/q/SE/Umea.json")
json = json.loads(url.text)
print json['current_observation']['temp_c']
Hope this can help you with your coding.
“Knock, knock.” - “Who’s there?” - very long pause…. - “Java.”
If a python knocks on your door and says “Hi, I’m a vacuum cleaner!” it’s not true. That’s a python.
Return to “Python”
