aidanmack
rpi.gpio error 'module' object has no attribute 'setmode'
Thu Jun 20, 2013 4:00 pm
Hi all,
Im trying to use RPI.GPIO
...But not gettting very far at all
This is my code...
try:
    import RPi.GPIO as GPIO
except RuntimeError:
    print("Error")
print(str(GPIO))
GPIO.setmode(GPIO.BOARD)
my print returns...
<module 'RPi.GPIO' from '/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/RPi/GPIO/__init__.pyc'>
and the error I get is....
File "rpigiotest.py", line 11, in <module>
Anyone any ideas where I could be going wrong..
samson241
Re: rpi.gpio error 'module' object has no attribute 'setmod
Thu Jun 20, 2013 6:08 pm
possibly setMode? been a long time sice I used this. :?
I realize this question must seem stupid and i apologize in advance.
cae2100
Thu Jun 20, 2013 7:48 pm
first, try to do "sudo apt-get update && sudo apt-get upgrade" to get rid of the chance that it's just an old version, and here's a short tutorial on the GPIO pins and python:
http://cae2100.wordpress.com/2013/01/10 ... in-python/
hope that helps.
If it isnt smoking and blown into pieces, it's not pushed far enough yet. :P
davef21370
Thu Jun 20, 2013 8:16 pm
Could you post your code in full? The error is apparently in line 11 but you don't seem to have that many lines.
Dave.
Apple say... Monkey do !!
croston
Thu Jun 20, 2013 9:21 pm
You have a really ancient version of RPi.GPIO - before setmode() was added. I suggest you upgrade it. As you have manually installed it, you will have to manually delete it to pick up the latest version from Raspbian.
aidanmack
Fri Jun 21, 2013 9:14 am
Sweet! manual delete and reinstall worked!
impressive that you spotted it was an old version mate! good work.
Cheers fellas.
Jaws84
Mon Jul 15, 2013 5:34 pm
I have the exact same problem with my rpi.gpio package.
How exactly did you solve it?
sudo apt-get --purge remove python3-rpi.gpio python-rpi.gpio
sudo apt-get install python3-rpi.gpio python-rpi.gpio
didn't work for me.
jesusbarazartem
Fri Sep 12, 2014 8:38 pm
Hi guys, i have a similar problem with it.
this is the error:
File "Blink.py", line 4, in <module>
GPIO.setmode(GPIO.BMC)
AttributeError: 'module' object has no attribute 'BMC'
And this is my code:
import time
GPIO.setup(18,GPIO.OUT)
while True:
GPIO.output(18,GPIO.HIGH)
time.sleep(1)
GPIO.output(18,GPIO.LOW)
time.sleep(1)
i did before
$ sudo apt-get update
$ sudo apt-get dist-upgrade
$ sudo apt-get install python-rpi.gpio python3-rpi.gpio
But it doesn't work yet
What this error means? what i should do?
somebody help me
eternalfame
Sat Sep 13, 2014 6:08 am
jesusbarazartem wrote:Hi guys, i have a similar problem with it.
this is the error:
import time
while True:
time.sleep(1)
time.sleep(1)
i did before
somebody help me
It's BCM not BMC
jesusbarazartem
Mon Sep 15, 2014 3:18 pm
Thanks eternalfame wow i didn't see before... thinks that can happen !!
chgus
Thu Feb 26, 2015 1:19 pm
i guess i'm on to the cause of this problem.
One upon a time I installed a 0.1.0 version GPIO on my very first Pi board. Since then RPi.GPIO has become part of the distribution and is installed by apt-get install command. Got the instructions from a web page after some google check. It might have been installed using easy_install, but i'm not shure.
I am now stuck with two versions, 0.1.0 and 0.5.7 at the same time ...
chgus@raspberrypi:~$ find /usr | grep -i gip
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/RPi/__init__.pyc
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/top_level.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/PKG-INFO
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/SOURCES.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/dependency_links.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/zip-safe
/usr/local/lib/python3.2/dist-packages/RPi.GPIO-0.5.7.egg-info
/usr/local/lib/python3.2/dist-packages/RPi.GPIO-0.5.7.egg-info/top_level.txt
/usr/local/lib/python3.2/dist-packages/RPi.GPIO-0.5.7.egg-info/PKG-INFO
/usr/local/lib/python3.2/dist-packages/RPi.GPIO-0.5.7.egg-info/installed-files.txt
/usr/local/lib/python3.2/dist-packages/RPi.GPIO-0.5.7.egg-info/SOURCES.txt
/usr/local/lib/python3.2/dist-packages/RPi.GPIO-0.5.7.egg-info/dependency_links.txt
/usr/local/lib/python3.2/dist-packages/RPi/GPIO.cpython-32mu.so
While i was prepairing this post i found out that it was even worse: I have three versions installed, 0.1.0, 0.5.7 and 0.5.11. 0.5.11 installs with apt-get install python-dpi.gpio and get updated as new releases become available.
My solution was to 'easy_install' away the ancient 0.1.0 by
sudo easy_install -m RPi.GPIO-0.1.0
Even though there still is a 0.5.7 version lurking around, the version reported both by pydoc and .VESRION is now 0.5.11
python
Python 2.7.3 (default, Mar 18 2014, 05:13:23)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import RPi.GPIO
>>> RPi.GPIO.VERSION
'0.5.11'
Jeff7beck
Mon May 18, 2015 2:20 am
hey guys i keep getting this error code am not sure what the problem is, can anyone help please.
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1437, in __call__
return self.func(*args)
File "/home/pi/robotics/robot2.pi", line 64, in key_input
init()
File "/home/pi/robotics/robot2.pi", line 9, in init
gpio.setup(7, gpio.out)
AttributeError: 'module' object has no attribute 'out'
here is a copy of my code
import RPi.GPIO as gpio
import time
import sys
import Tkinter as tk
def init():
gpio.setmode(gpio.BOARD)
gpio.setup(11, gpio.OUT)
gpio.setup(13, gpio.OUT)
gpio.setup(15, gpio.OUT)
def forward(tf):
gpio.output(7, False)
gpio.output(11, True)
gpio.output(13, True)
gpio.output(15, False)
time.sleep(tf)
gpio.cleanup()
def reverse(tf):
gpio.output(7, True)
gpio.output(11, False)
gpio.output(13, False)
gpio.output(15, True)
time.sleep(tf)
gpio.cleanup()
def turn_left():
time.sleep(tf)
gpio.cleanup()
def turn_right():
time.sleep(tf)
gpio.cleanup()
def pivot_left(tf):
time.sleep(tf)
gpio.cleanup()
def pivot_right(tf):
time.sleep(tf)
gpio.cleanup()
def key_input(event):
init()
print'Key:', event.char
key_press = event.char
sleep_time = .040
if key_press.lower() == 'w':
forward(sleep_time)
elif key_press.lower() == 's':
reverse(sleep_time)
elif key_press.lower() == 'a':
turn_left(sleep_time)
elif key_press.lower() == 'd':
turn_right(sleep_time)
elif key_press.lower() == 'q':
pivot_left(sleep_time)
elif key_press.lower() == 'e':
pivot_right(sleep_time)
else:
pass
command = tk.Tk()
command.bind('<KeyPress>', key_input)
command.mainloop()
Mon May 18, 2015 7:52 am
When you post code on the forum please use [code]...[/code] tags as that makes your programs easier to read and it keeps the formatting (which is a syntax requirement for python).
#!/usr/bin/python
gpio_Pin_buzz = 8
gpio.setmode(gpio.BCM)
gpio.setwarnings(False)
gpio.setup(gpio_Pin_buzz, gpio.OUT)
gpio.output(gpio_Pin_buzz, gpio.LOW)
Python is case sensitive so GPIO.OUT is not the same as GPIO.out or gpio.out or gpio.OUT.
Return to “Python”
