DaveBlue
Is it possible to run 'omxplayer' from Python?
Sun Jun 16, 2013 5:58 pm
I am developing an application for a heritage railway museum, where the user selects one of a set of video clips from a menu using a keypad. Is it possible to embed a call to omxplayer within the Python code. The alternative is to read the return value from the Python code in a script and respond appropriately, but this seems to be a bit clunky!
Thanks in advance
Dave
cae2100
Re: Is it possible to run 'omxplayer' from Python?
Sun Jun 16, 2013 6:31 pm
try using search on the forums here, there's a ton of people that have done the same thing already. This is the first good result I found:
http://www.raspberrypi.org/phpBB3/viewt ... er#p220358
and this:
https://github.com/jbaiter/pyomxplayer
If it isnt smoking and blown into pieces, it's not pushed far enough yet. :P
http://cae2100.wordpress.com
texy
Mon Jun 17, 2013 10:06 am
you can use os.call
import os
call(["mplayer", "-vo", "fbdev2:/dev/fb1", "-x", "128", "-y", "160", "-zoom", "VfE_html5.mp4"])
Above is an an example for testing the screens I sell. This is for mplayer, but the process should be the same. You won't need the fdev2:/dev/fb1 bit ;-)
Texy
KenT
Tue Jun 18, 2013 8:24 pm
I'm currently working on an extension to my Pi Presents (see sig) which will allow just this ( assuming the keypad looks like a keyboard and gives alphanumeric character codes. If you want to write your own than pyomxplayer is a good way to go.
Note however that pyomxplayer will not work with the current omxplayer, the fix is simple as it just a matter of missing out the few lines that read the track details.
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
Return to “Python”
