jay123035
GPSd TCP socket test loop error
Wed May 29, 2013 5:43 am
first off thanks
i am new to programming and am trying to learn from the deep end.
my goal (at present): to have a loop that checks if GPSd is running on socket 2947 is so it prints 2 lines then sleeps for 30sec (30min) and checks again. if the Socket is "closed" it runs:
 sudo killall gpsd
(to be sure & safe) then
 sudo gpsd /dev/ttyAMA0 -F /var/run/gpsd.sock
and checks again in 10sec.
what i have pieced together:
import socket
import os
import time
#Simply change the host and port values
host = 'localhost'
port = 2947
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
while 1:
 s.connect((host, port))
 s.shutdown(2)
 print "Success connecting to "
 print host + " on port: " + str(port)
# os.system("cgps -s")
 time.sleep (30)
else:
 print "Cannot connect to "
 os.system("sudo killall gpsd")
 os.system("sudo gpsd /dev/ttyAMA0 -F /var/run/gpsd.sock")
 time.sleep (10)
what i get:
webide@raspberrypi /usr/share/adafruit/webide/repositories/my-pi-projects/ckeckfor_GPSd $ sudo python socketlooptest.py
localhost on port: 2947
  File "socketlooptest.py", line 11, in <module>
  File "/usr/lib/python2.7/socket.py", line 224, in meth
    return getattr(self._sock,name)(*args)
socket.error: [Errno 106] Transport endpoint is already connected
i do not even know were to start with this. any help would be appreciated. thanks again.
DaveDriesen
Re: GPSd TCP socket test loop error
Wed May 29, 2013 6:54 am
Hi -- You have a "while 1" and then an "else"..
the code in your "else" statement will never be executed.
Is that as intended?
I may be missing something..
Dave Driesen
Linux dev and oldskool elite
jay123035
Wed May 29, 2013 2:24 pm
no your not missing anything. i am just that novice.
can you point me to what i should replace so that the lower section of code is run if the socket is NOT open? Maybe try?
thanks
jay123035
Wed May 29, 2013 6:59 pm
import socket
import os
import time
host = 'localhost'
port = 2947
while 1:
 try:
  s.shutdown(2)
 #os.system("cgps -s")
  time.sleep(30)
 except:
  time.sleep(20)
so this new loop seams to work. at least the first time. but it can never connect a second+ time. i think i need to disconnect from the socket (because when i kill the loop and restart it the first try connects)
Cannot connect to
Cannot connect to
Cannot connect to
Cannot connect to
any ideas.
Return to “Python”
