nomissnigghih
SyntaxError: expected path separator ([)
Thu May 16, 2013 8:48 pm
I am experiencing a problem with accessing a google drive spreadsheet from my pi with gspread. Using the following code
>>> import gspread
>>> gc = gspread.login('username', 'password')
>>> spreadsheet=gc.open('Spreadsheet')
>>> Log_sheet = spreadsheet.worksheet("Sheet1")
>>> Log_sheet.acell('B1').value
'Value @ B1'
I have tried using the same code in the command line from my computer and it works fine with the result above.
The error happens on the pi after the line >>>Log_sheet = spreadsheet.worksheet("Sheet1")
Can anyone help?
ERROR
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python3.1/dist-packages/gspread/models.py", line 123, in worksheet
self._fetch_sheets()
File "/usr/local/lib/python3.1/dist-packages/gspread/models.py", line 62, in _fetch_sheets
self._sheet_list.append(Worksheet(self, elem))
File "/usr/local/lib/python3.1/dist-packages/gspread/models.py", line 168, in __init__
self.version = element.find(_ns("link[@rel='edit']")).attrib['href'].split('/')[-1]
File "/usr/lib/python3.1/xml/etree/ElementTree.py", line 305, in find
return ElementPath.find(self, path)
File "/usr/lib/python3.1/xml/etree/ElementPath.py", line 186, in find
return _compile(path).find(element)
File "/usr/lib/python3.1/xml/etree/ElementPath.py", line 176, in _compile
p = Path(path)
File "/usr/lib/python3.1/xml/etree/ElementPath.py", line 93, in __init__
"expected path separator (%s)" % (op or tag)
I have tried reinstalling elementtree, I have also tried python 3.1, still no joy
please can anyone help?
timhoffman
Re: SyntaxError: expected path separator ([)
Fri May 17, 2013 1:11 am
Check you are using the same version of python on the working machine.
nomissnigghih
Fri May 17, 2013 3:38 pm
Tim,
Thank you for replying yes its the same version using python -v to check
timhoffman
Sat May 18, 2013 1:42 pm
Check and see if you have lxml installed on your desktop. Your XML parsing may be devolving to elementree without lxml present and hence the error.
nomissnigghih
Sat May 18, 2013 2:02 pm
Thank you Tim, I have checked on the pi and I have lxml installed
/usr/lib/pyshared/python2.6/lxml
/usr/lib/python2.6/dist-packages/lxml
Please could you provide a little more on what believe the problem might be, I perhaps didn't understand?
corranwebster
Tue May 21, 2013 2:52 am
It looks like you have lxml installed for Python 2.6, but not Python 3.1.
This means that your Python 3 code will be getting the standard library version of elementree, rather than lxml's improved one, which may account for the error that you are seeing.
Your options would seem to be to install lxml for Python 3, or to install gscript in Python 2.6 and run your code with Python 2.
-- Corran
corranwebster
Tue May 21, 2013 2:54 am
In the interest of avoiding clarity: I mis-typed 'gscript' where I meant 'gspread' in the previous post.
davef21370
Tue May 21, 2013 6:38 pm
Try
Log_sheet=gc.open('Spreadsheet').sheet1
Dave.
Apple say... Monkey do !!
nomissnigghih
Tue May 21, 2013 9:36 pm
HI Thank you for your replies. I have couldn't work it out, I pullout the SD card, reloaded the Debian Wheezy (latest version) and started over. All working now. I have 2.7 and 3.1, after installing GSPREAD, both worked as expected from IDLE able to login and extract values.
I can confirm the latest Debian Wheezy works with GSPREAD, I did have a very early version on my PI and have been installing alsorts of software trying different combinations.
BTW the latest version has a colour cusor - I was impressed! (Little things)
Return to “Python”
Who is online
Users browsing this forum: No registered users and 14 guests
