start gui auto
Posted: Wed May 15, 2013 1:39 am
by aijam
I hope rpi starts up a tkinter gui program auto after rpi boot.
If I run this file.py in console.
_tkinter.TclError: no display name and no $DISPLAY environment variable
But I don't wanna startx or starlxde because of the performance of rpi.
I have tested Java 8 preview for ARM hf.
And jar can run in console.
Re: start gui auto
Posted: Wed May 15, 2013 7:31 am
by mrpi64
i think if you turn the file into an executable, and then change the last line(I THINK) in '/etc/profile' (AKA: put in the command ./script-name), it might work.
turn the file into executable by:
chmod -x script-name.py
then edit the profile file using:
sudo nano /etc/profile
hope this helps:
mrpi64
Re: start gui auto
Posted: Wed May 15, 2013 8:07 am
by rurwin
So far as I can Google, Tk requires an X server to be running. There is no implementation of Tk for a simple framebuffer such as the text console. It is possible to strip down your X session to the bare minimum -- no desktop manager, maybe no window manager (or maybe use something truly tiny such as twm.) But you will still need startx.
Re: start gui auto
Posted: Wed May 15, 2013 9:09 am
by DaveDriesen
Thanks -- just a note on the following:
To make your file executable you would need
chmod +x
chmod -x turns the executable bit off, not on)
Also you can research /etc/rc.local for starting stuff at boot
Dave Driesen
Linux dev and oldskool elite
Re: start gui auto
Posted: Thu May 16, 2013 2:21 pm
by aijam
rurwin wrote:So far as I can Google, Tk requires an X server to be running. There is no implementation of Tk for a simple framebuffer such as the text console. It is possible to strip down your X session to the bare minimum -- no desktop manager, maybe no window manager (or maybe use something truly tiny such as twm.) But you will still need startx.
I installed twm and add a .xinitrc under home directory.
.xinitrc
exec twm
python test.py
It works after log in.
Thanks.
Re: start gui auto
Posted: Thu May 16, 2013 2:25 pm
by aijam
mrpi64 wrote:i think if you turn the file into an executable, and then change the last line(I THINK) in '/etc/profile' (AKA: put in the command ./script-name), it might work.
hope this helps:
mrpi64
I also modified /etc/profile.
But after log in, console print some error.
It means Tk still need a X environment.
