terryspitz
IronPython on mono
Sat Apr 27, 2013 10:00 am
Trouble running IronPython... does anyone have this working? See my crash dump below.
I have the latest mono install (sudo apt-get install mono-complete). I copied the 2.7.4 IronPython binaries onto the Pi and ran ipy.exe with the sample code from Wikipedia.
Any ideas?
thanks
pi@raspberrypi ~/src/IronPython-2.7.3 $ mono ipy.exe
IronPython 2.7.3 (2.7.0.40) on Mono 4.0.30319.1 (32-bit)
Type "help", "copyright", "credits" or "license" for more information.
>>> import clr
>>> clr.AddReference("System.Windows.Forms")
>>> from System.Windows.Forms import MessageBox
>>> MessageBox.Show("Hello World")
Stacktrace:
  at System.Drawing.Font.CreateFont (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x00143>
  at System.Drawing.Font..ctor (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x0007f>
  at System.Drawing.Font..ctor (string,single,string) <0x00057>
  at (wrapper remoting-invoke-with-check) System.Drawing.Font..ctor (string,single,string) <0xffffffff>
  at System.Drawing.SystemFonts.get_DefaultFont () <0x00073>
  at System.Windows.Forms.Theme..ctor () <0x0002f>
  at System.Windows.Forms.ThemeWin32Classic..ctor () <0x00013>
  at System.Windows.Forms.ThemeEngine..cctor () <0x000a3>
  at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) <0xffffffff>
  at System.Windows.Forms.SystemInformation.get_MenuAccessKeysUnderlined () <0x00007>
  at System.Windows.Forms.Control..ctor () <0x001ef>
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control..ctor () <0xffffffff>
  at System.Windows.Forms.WindowsFormsSynchronizationContext..cctor () <0x0002b>
  at System.Windows.Forms.Control..ctor () <0x0004b>
  at System.Windows.Forms.ScrollableControl..ctor () <0x00013>
  at System.Windows.Forms.ContainerControl..ctor () <0x00023>
  at System.Windows.Forms.Form..ctor () <0x00073>
  at System.Windows.Forms.MessageBox/MessageBoxForm..ctor (System.Windows.Forms.IWin32Window,string,string,System.Windows.Forms.MessageBoxButtons,System.Windows.Forms.MessageBoxIcon,bool) <0x00053>
  at System.Windows.Forms.MessageBox/MessageBoxForm..ctor (System.Windows.Forms.IWin32Window,string,string,System.Windows.Forms.MessageBoxButtons,System.Windows.Forms.MessageBoxIcon) <0x00057>
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.MessageBox/MessageBoxForm..ctor (System.Windows.Forms.IWin32Window,string,string,System.Windows.Forms.MessageBoxButtons,System.Windows.Forms.MessageBoxIcon) <0xffffffff>
  at System.Windows.Forms.MessageBox.Show (string) <0x00063>
  at Microsoft.Scripting.Interpreter.FuncCallInstruction`2<string, System.Windows.Forms.DialogResult>.Run (Microsoft.Scripting.Interpreter.InterpretedFrame) <0x0007f>
  at Microsoft.Scripting.Interpreter.Interpreter.Run (Microsoft.Scripting.Interpreter.InterpretedFrame) <0x0009f>
  at Microsoft.Scripting.Interpreter.LightLambda.Run4<T0, T1, T2, T3, TRet> (T0,T1,T2,T3) <0x00157>
  at System.Dynamic.UpdateDelegates.UpdateAndExecute3<T0, T1, T2, TRet> (System.Runtime.CompilerServices.CallSite,T0,T1,T2) <0x0040b>
  at (wrapper delegate-invoke) <Module>.invoke_object__this___CallSite_CodeContext_object_object (System.Runtime.CompilerServices.CallSite,IronPython.Runtime.CodeContext,object,object) <0xffffffff>
  at (wrapper delegate-invoke) <Module>.invoke_object__this___Func`5<CallSite, CodeContext, object, object, object>_CallSite_CodeContext_object_object (System.Func`5<System.Runtime.CompilerServices.CallSite, IronPython.Runtime.CodeContext, object, object, object>,System.Runtime.CompilerServices.CallSite,IronPython.Runtime.CodeContext,object,object) <0xffffffff>
  at Microsoft.Scripting.Interpreter.FuncCallInstruction`6.Run (Microsoft.Scripting.Interpreter.InterpretedFrame) <0x001d3>
  at IronPython.Compiler.Ast.CallExpression/Invoke1Instruction.Run (Microsoft.Scripting.Interpreter.InterpretedFrame) <0x000a3>
  at Microsoft.Scripting.Interpreter.LightLambda.Run2<T0, T1, TRet> (T0,T1) <0x000f7>
  at IronPython.Compiler.PythonScriptCode.RunWorker (IronPython.Runtime.CodeContext) <0x0006f>
  at IronPython.Compiler.PythonScriptCode.Run (Microsoft.Scripting.Runtime.Scope) <0x0004f>
  at IronPython.Hosting.PythonCommandLine/<>c__DisplayClass1.<RunOneInteraction>b__0 () <0x00087>
  at IronPython.Runtime.PythonContext.DispatchCommand (System.Action) <0x00043>
  at IronPython.Hosting.PythonCommandLine.RunOneInteraction () <0x002ab>
  at IronPython.Hosting.PythonCommandLine.TryInteractiveActionWorker () <0x0004f>
  at IronPython.Hosting.PythonCommandLine.TryInteractiveAction () <0x00037>
  at Microsoft.Scripting.Hosting.Shell.CommandLine.RunInteractiveLoop () <0x000ef>
  at IronPython.Hosting.PythonCommandLine.RunInteractive () <0x00163>
  at Microsoft.Scripting.Hosting.Shell.CommandLine.Run () <0x00097>
  at IronPython.Hosting.PythonCommandLine.Run () <0x0036f>
  at Microsoft.Scripting.Hosting.Shell.CommandLine.Run (Microsoft.Scripting.Hosting.ScriptEngine,Microsoft.Scripting.Hosting.Shell.IConsole,Microsoft.Scripting.Hosting.Shell.ConsoleOptions) <0x000d3>
  at Microsoft.Scripting.Hosting.Shell.ConsoleHost.RunCommandLine () <0x000fb>
  at Microsoft.Scripting.Hosting.Shell.ConsoleHost.ExecuteInternal () <0x000ab>
  at PythonConsoleHost.ExecuteInternal () <0x0006f>
  at Microsoft.Scripting.Hosting.Shell.ConsoleHost.Execute () <0x000bf>
  at Microsoft.Scripting.Hosting.Shell.ConsoleHost.Run (string[]) <0x00483>
  at PythonConsoleHost.Main (string[]) <0x00073>
  at (wrapper runtime-invoke) <Module>.runtime_invoke_int_object (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
Debug info from gdb:
Cannot access memory at address 0x0
Cannot access memory at address 0x1
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0xb59ff460 (LWP 13778)]
[New Thread 0xb5ce7460 (LWP 13758)]
[New Thread 0xb688a460 (LWP 13658)]
0xb6f267d0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
  Id   Target Id         Frame
  4    Thread 0xb688a460 (LWP 13658) "mono" 0xb6f25700 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
  3    Thread 0xb5ce7460 (LWP 13758) "mono" 0xb6f27250 in nanosleep () from /lib/arm-linux-gnueabihf/libpthread.so.0
  2    Thread 0xb59ff460 (LWP 13778) "mono" 0xb6f25954 in sem_timedwait () from /lib/arm-linux-gnueabihf/libpthread.so.0
* 1    Thread 0xb6ff9000 (LWP 13657) "mono" 0xb6f267d0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 4 (Thread 0xb688a460 (LWP 13658)):
#0  0xb6f25700 in sem_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1  0x00195a40 in mono_sem_wait ()
#2  0x000ea384 in ?? ()
#3  0x000ea384 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 3 (Thread 0xb5ce7460 (LWP 13758)):
#0  0xb6f27250 in nanosleep () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1  0xb6f26044 in __pthread_enable_asynccancel () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2  0x0018fe08 in ?? ()
#3  0x0018fe08 in ?? ()
Thread 2 (Thread 0xb59ff460 (LWP 13778)):
#0  0xb6f25954 in sem_timedwait () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1  0x00195b20 in mono_sem_timedwait ()
#2  0x0015f80c in ?? ()
#3  0x0015f80c in ?? ()
Thread 1 (Thread 0xb6ff9000 (LWP 13657)):
#0  0xb6f267d0 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2  0x00096e60 in ?? ()
#3  0x00096e60 in ?? ()
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted
pi@raspberrypi ~/src/IronPython-2.7.3 $ dmesg | grep Linux
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Linux version 3.6.11+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #371 PREEMPT Thu Feb 7 16:31:35 GMT 2013
pi@raspberrypi ~/src/IronPython-2.7.3 $ mono -V
Mono JIT compiler version 2.10.8.1 (Debian 2.10.8.1-5)
terryspitz
Re: IronPython on mono
Sun Apr 28, 2013 4:55 pm
http://www.raspberrypi.org/phpBB3/viewt ... 66&t=11634 says Winforms not supported on hard float Debian Wheezy.
Return to “Python”
