Pymunk problem
Posted: Sun Apr 21, 2013 11:46 am
by davef21370
I'm using a few snippets from the Pymunk Slide and Pin Joints example but when I try to create the 'static L' I only get the first line, here's how I'm creating it (only the definition name has changed)...
def add_bowl(space):
    body = pymunk.Body()
    body.position = (300,300)
    l1 = pymunk.Segment(body,(-150,0),(255,0),5)
    l2 = pymunk.Segment(body,(-150,0),(-150,50),5)
    space.add(l1,l2)
    return l1,l2
I have the same problem with the bouncing_balls demo (which I think is basically the same script) without changing anything.
What I need to do is create 2 walls and a floor to contain some balls.
Any help much appreciated.
Dave.
