mattanl
Motion detection
Mon Apr 15, 2013 3:10 pm
I want to implement motion detection using a simple webcam for my raspberry pi.
I've already done it few years ago in C# for my windows machine.
Do you know if is it possible to run motion detection algorithm on the pi? Do you know a python module for doing it?
Thanks.
piglet
Re: Motion detection
Mon Apr 15, 2013 3:52 pm
I may be missing something, but there's a package called motion you can use for this:
http://linux.die.net/man/1/motion
Graz
Mon Apr 15, 2013 4:11 pm
I found this post very helpful as an intro to motion on the pi :
http://through-the-interface.typepad.co ... art-1.html
Cheers,
Graz
mattanl
Mon Apr 15, 2013 4:12 pm
Thanks, but it doesn't seem like something I can embed in a program, or even a python script.
davef21370
Mon Apr 15, 2013 4:34 pm
Try OpenCV, loads of info on t'internet and works in C and Python, I've been playing with face detection over the weekend and it works a treat. Fairly sure there's motion detection in there too.
Cheers.
Dave.
Apple say... Monkey do !!
richiepp
Tue Apr 16, 2013 1:12 am
Not exactly what you're looking for but this could be informative
http://learn.adafruit.com/adafruits-ras ... g-movement
clixxio
Wed Apr 17, 2013 2:25 am
Motion is likely to be a good fit.
When it detects motion, it writes new .jpg files to the /tmp/motion directory.
You can poll this directory with your program and delete old files.
It's really extremely good at this. You only need to do this:
> sudo apt-get install motion
> sudo motion &
And it's running. Then write your code in whatever language you like.
AKopp
Wed Apr 17, 2013 11:05 am
and how can I access this temp file?
gordon77
Wed Apr 17, 2013 12:47 pm
image1 = pygame.image.load(/tmp/motion/<filename>) ?
Gordon77
AKopp
Wed Apr 17, 2013 1:03 pm
Hi Gordon,
I meant how can I see it.
I figured it out.
Its the ip of my rasperry pie and the port
In my case 192.168.178.1:6789
What I do not get now is how can I turn the motion app off.
clixxio
Wed Apr 17, 2013 11:20 pm
open your browser on the pi and type: http://127.0.0.1:8081
If you want to see it from other machines then you need to change the
configuration file /etc/motion/motion.conf:
webcam localhost on
to:
webcam localhost off
If you want to detect motion from python code use something like this:
import glob, os
 while (1):
   filelist = glob.glob('/tmp/motion/*.jpg')
   if len(filelist):
       print "I have detected motion"
       for f in filelist:
           os.unlink(f) # remove each file
   time.sleep(2) # wait a little bit of time
sudo killall motion
mattanl
Thu Apr 18, 2013 7:39 am
Thanks.
What if I have more than 1 camera connected?
Return to “Python”
