Petomni
Error #3 waiting for edge
Fri Apr 05, 2013 10:46 pm
Using GPIO.VERSION 0.5.1a I set up some code that listens to output from a PIR sensor that goes low when motion is detected. The code times how long the signal is low and records it.
while GPIO.input(PIN_BUTTON):
    GPIO.wait_for_edge(PIN_MOTION, GPIO.FALLING)
    #motion detected
    MotionStarted = datetime.now()
    GPIO.wait_for_edge(PIN_MOTION, GPIO.RISING)
    #motion ended
    MotionEnded = datetime.now()
    #write to file
    LogFile.write(str((MotionStarted - BeginMonitoring).total_seconds()))
    LogFile.write('\t')
    LogFile.write(str((MotionEnded - MotionStarted).total_seconds()))
    LogFile.write('\n')
Everything works for quite some time, hours even, but then randomly it will halt with the message "RuntimeError: Error #3 waiting for edge" at line 54 which confuses me as well because that line the comment "#motion detected"
Could anyone tell me what causes Error 3 waiting for edge?
croston
Re: Error #3 waiting for edge
Sat Apr 06, 2013 5:34 am
I'll have a look later today. It could well be something internal to the RPi.GPIO library and not your script that is at fault.
Petomni
Mon Apr 08, 2013 1:01 am
So I found this https://code.google.com/p/raspberry-gpi ... 167c2a#573
and line 573 seems like it's what would be triggering this response.
   Py_BEGIN_ALLOW_THREADS // disable GIL
   result = blocking_wait_for_edge(gpio, edge);
   Py_END_ALLOW_THREADS   // enable GIL
   if (result == 0) {
      Py_INCREF(Py_None);
      return Py_None;
   } else if (result == 2) {
      PyErr_SetString(AddEventException, "Edge detection events already enabled for this GPIO channel");
      return NULL;
   } else {
      sprintf(error, "Error #%d waiting for edge", result);
      PyErr_SetString(PyExc_RuntimeError, error);
      return NULL;
But I really have no idea if this is relevant or what this means but hopefully someone here does?
alexeames
Mon Apr 08, 2013 12:27 pm
Petomni wrote:But I really have no idea if this is relevant or what this means but hopefully someone here does?
Someone might. :lol:
Croston, who already replied to you, wrote RPi.GPIO, so it's highly probable he's the best man to help you. :ugeek:
Alex Eames RasPi.TV, RasP.iO
ericvrp
Wed May 15, 2013 5:34 am
I'm having the same problem.
bahex
Mon Jun 17, 2013 6:47 am
Hi Guys,
I have the same problem using the version 0.5.2a.
Thanks for any help on this...
ahmedhussain85
Tue Apr 29, 2014 1:53 pm
Hi
I have the same problem but after 1000+ interrupts. The code I am using now works perfect until 1000+ interrupts and then crashes badly and gives RunTimeError # 3 waiting for edge...
I am using GPIO.cleanup() and I am also using latest version of RPi.GPIO
Any help would be appreciated.
Thanks a lot!
Ahmed: [email protected]
Helmi Romdhani
Fri Dec 26, 2014 1:01 pm
Hi guys!
Just add time.sleep(0.01) before the waiting for edge line to avoid blocking the processor.
Return to “Python”
