GPIO.setmode(GPIO.BCM) error
Posted: Sun Mar 24, 2013 8:25 am
by darthvazor
#!/usr/bin/env python2.7
# script by Alex Eames http://RasPi.tv
# http://RasPi.tv/how-to-use-interrupts-with-python-on-the-raspberry-pi-and-rpi-gpio-part-3
import RPi.GPIO as GPIO
import time
# GPIO 23 & 17 set up as inputs, pulled up to avoid false detection.
# Both ports are wired to connect to GND on button press.
# So we'll be setting up falling edge detection for both
GPIO.setup(23, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(17, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# GPIO 24 set up as an input, pulled down, connected to 3V3 on button press
GPIO.setup(24, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
time_stamp = time.time()
time_stamp2 = time.time()
# now we'll define two threaded callback functions
# these will run in another thread when our events are detected
def my_callback():
    global time_stamp       # put in to debounce
    time_now = time.time()
    if (time_now - time_stamp) >= 0.3:
        print "falling edge detected on 17"
    time_stamp = time_now
def my_callback2():
    global time_stamp2       # put in to debounce - note we need a second time stamp
    if (time_now - time_stamp2) >= 0.3:
        print "falling edge detected on 23"
    time_stamp2 = time_now
print "Make sure you have a button connected so that when pressed"
print "it will connect GPIO port 23 (pin 16) to GND (pin 6)\n"
print "You will also need a second button connected so that when pressed"
print "it will connect GPIO port 24 (pin 18) to 3V3 (pin 1)\n"
print "You will also need a third button connected so that when pressed"
print "it will connect GPIO port 17 (pin 11) to GND (pin 14)"
raw_input("Press Enter when ready\n>")
# when a falling edge is detected on port 17, regardless of whatever
# else is happening in the program, the function my_callback will be run
GPIO.add_event_detect(17, GPIO.FALLING, callback=my_callback)
# when a falling edge is detected on port 23, regardless of whatever
# else is happening in the program, the function my_callback2 will be run
GPIO.add_event_detect(23, GPIO.FALLING, callback=my_callback2)
try:
    print "Waiting for rising edge on port 24"
    GPIO.wait_for_edge(24, GPIO.RISING)
    print "Rising edge detected on port 24. Here endeth the third lesson."
except KeyboardInterrupt:
    GPIO.cleanup()       # clean up GPIO on CTRL+C exit
GPIO.cleanup()           # clean up GPIO on normal exit
I tried this tutorial code and it didn't work. The error said:
File "test1.py", line 6, in <module>
AttributeError: 'module' object has no attribute 'setmode'
I tried GPIO.BOARD too and it still not working. I already installed RPi.GPIO most current version 0.5.1a. Please help me, your help would be appreciated.
Re: GPIO.setmode(GPIO.BCM) error
Posted: Sun Mar 24, 2013 8:47 am
by malakai
What happens when you run this:
sudo python
GPIO.VERSION
I would imagine if it errors there is a problem with the RPi.GPIO do you have a file named RPi.GPIO in the same directory?
Posted: Sun Mar 24, 2013 8:53 am
by alexeames
Sounds like you have an old version of RPi.GPIO. Setmode was introduced in August 2011. In "Pi speed" that's about 4 generations ago. :lol:
It shows you how to update on the same page you got the code from.
The interrupts were only released last week, you need the very latest RPi.GPIO 0.5.1a for this script to work. (And there will be an even newer version soon with PWM and debounce).
Is it possible your install went wrong? How did you do it?
Posted: Sun Mar 24, 2013 9:32 am
by croston
Sounds like you have installed RPi.GPIO manually from source at some point. What is the result of:
$ find /usr | grep -i gpio
Posted: Mon Mar 25, 2013 7:09 pm
by darthvazor
@ Croston
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.1a.egg-info
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.1a.egg-info/top_level.txt
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.1a.egg-info/SOURCES.txt
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.1a.egg-info/dependency_links.txt
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.1a.egg-info/PKG-INFO
/usr/lib/python2.6/dist-packages/RPi/GPIO.so
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.1a.egg-info
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.1a.egg-info/top_level.txt
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.1a.egg-info/SOURCES.txt
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.1a.egg-info/dependency_links.txt
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.1a.egg-info/PKG-INFO
/usr/lib/python2.7/dist-packages/RPi/GPIO.so
/usr/lib/python3/dist-packages/RPi/GPIO.cpython-32mu.so
/usr/lib/python3/dist-packages/RPi.GPIO-0.4.1a.egg-info
/usr/lib/python3/dist-packages/RPi.GPIO-0.4.1a.egg-info/top_level.txt
/usr/lib/python3/dist-packages/RPi.GPIO-0.4.1a.egg-info/SOURCES.txt
/usr/lib/python3/dist-packages/RPi.GPIO-0.4.1a.egg-info/dependency_links.txt
/usr/lib/python3/dist-packages/RPi.GPIO-0.4.1a.egg-info/PKG-INFO
/usr/lib/pyshared/python2.6/RPi/GPIO.so
/usr/lib/pyshared/python2.7/RPi/GPIO.so
/usr/share/doc/python-rpi.gpio
/usr/share/doc/python-rpi.gpio/changelog.Debian.gz
/usr/share/doc/python-rpi.gpio/copyright
/usr/share/doc/python-rpi.gpio/changelog.gz
/usr/share/doc/python3-rpi.gpio
/usr/share/doc/python3-rpi.gpio/changelog.Debian.gz
/usr/share/doc/python3-rpi.gpio/copyright
/usr/share/doc/python3-rpi.gpio/changelog.gz
/usr/share/pyshared/RPi.GPIO-0.5.1a.egg-info
/usr/share/pyshared/RPi.GPIO-0.5.1a.egg-info/top_level.txt
/usr/share/pyshared/RPi.GPIO-0.5.1a.egg-info/dependency_links.txt
/usr/share/pyshared/RPi.GPIO-0.5.1a.egg-info/PKG-INFO
/usr/local/lib/python2.7/dist-packages/WebIOPi-0.5.3-py2.7-linux-armv6l.egg/_web                                                         iopi/GPIO.py
/usr/local/lib/python2.7/dist-packages/WebIOPi-0.5.3-py2.7-linux-armv6l.egg/_web                                                         iopi/GPIO.so
/usr/local/lib/python2.7/dist-packages/WebIOPi-0.5.3-py2.7-linux-armv6l.egg/_web                                                         iopi/GPIO.pyc
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/RPi
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/RPi/__init__.py
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/RPi/GPIO
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/RPi/GPIO/__init_                                                         _.py
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/RPi/GPIO/__init_                                                         _.pyc
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/RPi/__init__.pyc
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/zip-saf                                                         e
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/top_lev                                                         el.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/SOURCES                                                         .txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/depende                                                         ncy_links.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0-py2.7.egg/EGG-INFO/PKG-INF                                                         O
/usr/local/lib/python3.2/dist-packages/WebIOPi-0.5.3-py3.2-linux-armv6l.egg/_web                                                         iopi/GPIO.py
/usr/local/lib/python3.2/dist-packages/WebIOPi-0.5.3-py3.2-linux-armv6l.egg/_web                                                         iopi/__pycache__/GPIO.cpython-32.pyc
/usr/local/lib/python3.2/dist-packages/WebIOPi-0.5.3-py3.2-linux-armv6l.egg/_web                                                         iopi/GPIO.cpython-32mu.so
/usr/local/bin/gpio
/usr/local/share/man/man1/gpio.1
@Malakai
Python 2.7.3 (default, Jan 13 2013, 11:20:46)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> GPIO.VERSION
  File "<stdin>", line 1, in <module>
AttributeError: 'module' object has no attribute 'VERSION'
Posted: Mon Mar 25, 2013 7:36 pm
by croston
Spotted your problem. You have manually installed RPi.GPIO 0.1.0 at some point in the distant past and this one takes precidence over any copy installed using apt-get.
To remove it:
$ sudo rm -rf /usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.1.0*
Posted: Mon Mar 25, 2013 7:48 pm
by darthvazor
It works! Thank you, Croston! :)
Posted: Sun Mar 31, 2013 2:58 pm
by adelghouari
hi all; me too i have this problem; i"m going to preperd this my ferst exempal with my pi; but if i make sudo python
Posted: Sun Mar 31, 2013 3:13 pm
by adelghouari
after these commands ligne
[email protected] ~ $ sudo python
>>> GPIO.setmod(GPIO.BCM)
AttributeError: 'module' object has no attribute 'setmod'
i"m not understand; but after reading your messages i make this
>>> GPIO.VERSION
'0.5.2a'
there is not others version of GPIO.
sorry; if i make >> GPIO.setmod(GPIO.BCM)
@raspberrypi ~ $ find /usr | grep -i gpio
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.2a.egg-info
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.2a.egg-info/top_level.txt
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.2a.egg-info/SOURCES.txt
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.2a.egg-info/dependency_links.txt
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.2a.egg-info/PKG-INFO
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a.egg-info
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a.egg-info/top_level.txt
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a.egg-info/SOURCES.txt
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a.egg-info/dependency_links.txt
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a.egg-info/PKG-INFO
/usr/share/pyshared/RPi.GPIO-0.5.2a.egg-info
/usr/share/pyshared/RPi.GPIO-0.5.2a.egg-info/top_level.txt
/usr/share/pyshared/RPi.GPIO-0.5.2a.egg-info/dependency_links.txt
/usr/share/pyshared/RPi.GPIO-0.5.2a.egg-info/PKG-INFO
please i need your help thank you
Posted: Sun Mar 31, 2013 3:16 pm
by croston
Try using setmode with an 'e' on the the end, not setmod.
Posted: Sun Mar 31, 2013 3:24 pm
by adelghouari
croston thank you; i'm not good today
thank's
Posted: Sun Jun 09, 2013 2:11 pm
by alexszilagyi
Hi there,
I'm running in the same issue, can anyone help me to check my log:
/usr/share/webiopi/htdocs/app/gpio-list
/usr/share/webiopi/htdocs/app/gpio-list/index.html
/usr/share/webiopi/htdocs/app/gpio-header
/usr/share/webiopi/htdocs/app/gpio-header/index.html
/usr/lib/python3/dist-packages/RPi.GPIO-0.5.2a.egg-info
/usr/lib/python3/dist-packages/RPi.GPIO-0.5.2a.egg-info/top_level.txt
/usr/lib/python3/dist-packages/RPi.GPIO-0.5.2a.egg-info/PKG-INFO
/usr/lib/python3/dist-packages/RPi.GPIO-0.5.2a.egg-info/SOURCES.txt
/usr/lib/python3/dist-packages/RPi.GPIO-0.5.2a.egg-info/dependency_links.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/RPi
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/RPi/GPIO.pyc
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/RPi/__init__.pyc
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/RPi/GPIO.so
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/EGG-INFO
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/EGG-INFO/top_level.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/EGG-INFO/PKG-INFO
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/EGG-INFO/SOURCES.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/EGG-INFO/dependency_links.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/EGG-INFO/native_libs.txt
/usr/local/lib/python2.7/dist-packages/RPi.GPIO-0.5.2a-py2.7-linux-armv6l.egg/EGG-INFO/zip-safe
/usr/local/lib/python2.7/dist-packages/WebIOPi-0.6.0-py2.7-linux-armv6l.egg/webiopi/devices/digital/gpio.pyc
/usr/local/lib/python2.7/dist-packages/WebIOPi-0.6.0-py2.7-linux-armv6l.egg/_webiopi/GPIO.pyc
/usr/local/lib/python2.7/dist-packages/WebIOPi-0.6.0-py2.7-linux-armv6l.egg/_webiopi/GPIO.so
/usr/local/lib/python3.2/dist-packages/WebIOPi-0.6.0-py3.2-linux-armv6l.egg/webiopi/devices/digital/__pycache__/gpio.cpython-32.pyc
/usr/local/lib/python3.2/dist-packages/WebIOPi-0.6.0-py3.2-linux-armv6l.egg/webiopi/devices/digital/gpio.py
/usr/local/lib/python3.2/dist-packages/WebIOPi-0.6.0-py3.2-linux-armv6l.egg/_webiopi/__pycache__/GPIO.cpython-32.pyc
/usr/local/lib/python3.2/dist-packages/WebIOPi-0.6.0-py3.2-linux-armv6l.egg/_webiopi/GPIO.py
/usr/local/lib/python3.2/dist-packages/WebIOPi-0.6.0-py3.2-linux-armv6l.egg/_webiopi/GPIO.cpython-32mu.so
While running this: https://dpaste.de/qWLad/ I get this: http://severo.ro/RaspberryPi/ModuleNotI ... rectly.png
I'd appreciate any help ;)
Posted: Fri Oct 18, 2013 9:27 am
by vijay_nav
i am facing the same error can any help me
this is my code
GPIO.setmode(gpio.BCM)
GPIO.setup(7,GPIO.IN)
GPIO.setup(8,GPIO.OUT)
input_value=GPIO.input(7)
GPIO.output(8,True)
while executing the code i am getting the error as
File "vijay.py", line 2, in <module>
NameError: name 'gpio' is not defined
i have checked with my gpio package
/usr/share/pyshared/RPi.GPIO-0.5.3a.egg-info
/usr/lib/python2.7/dist-packages/RPi.GPIO-0.5.3a.egg-info
/usr/lib/python3/dist-packages/RPi.GPIO-0.5.3a.egg-info
/usr/lib/python2.6/dist-packages/RPi.GPIO-0.5.3a.egg-info
please help me .....................................
Posted: Fri Oct 18, 2013 9:44 am
by vijay_nav
who get's error of Traceback (most recent call last):
just try with this GPIO.setmode(GPIO.BOARD)
instead of GPIO.setmode(GPIO.BCM)
Posted: Fri Oct 18, 2013 10:04 am
by clive
Python is case sensitive : use 'GPIO' not 'gpio' in line 2
Posted: Fri Oct 18, 2013 10:07 am
by clive
vijay_nav wrote:who get's error of Traceback (most recent call last):
just be aware that the pins will be referenced in numerical order in BOARD mode.
Posted: Fri Feb 08, 2019 9:48 pm
by TimDeWeasel
When i try to run example code from CanaKit's included star-up booklet Raspberry Pi for Dummies.
import RPi.GPIO
import time
LED_on = True
LED_off = False
GPIO.setmode (GPIO.BCM)
GPIO.setupmode (18, GPIO.OUT)
GPIO.output (18, LED_on)
When I try to run it I get the following:
File "/home/pi/one LED.py". line 5 in <module>
NameError: name 'GPIO' is not defined
I am obviously new to Python and Linux and do not know enough to debug this problem.
Posted: Fri Feb 08, 2019 11:15 pm
by B.Goode
Welcome to the Raspberry Pi forums.
import RPi.GPIO
import time
LED_on = True
LED_off = False
If you have a problem with code or documentation supplied on a commercial basis by a third party perhaps you should seek advice from them.
The error message is quite succinct and accurate: nowhere in your script do you provide a definition of GPIO.
The usual way to make RPi.GPIO features available within your script is to use the following:
Edit: just to add - the documentation here http://www.canakit.com/Media/CanaKit-Ra ... de-3.2.pdf appears to show the first line of the sample scripts as I have indicated.
Posted: Sat Feb 09, 2019 12:31 pm
by TimDeWeasel
;) That did it! thanks
