bltsandwich1
Printing to file from arduino serial output
Thu Mar 21, 2013 6:06 pm
I'm looking for a way to send the serial output from an Arduino connected via USB to the Pi.
I am going to be constantly reading data from a simple temperature sensor, and I am wondering if it is possible to copy the serial output to a file. Ideally I would like to do this with python because it is the language I know by far the most about.
I would like to be able to do this so that I don't need a GUI to copy and paste the info from the serial readout, and also because the Pi may lose power, and I want to make sure that the serial data is saved.
Thanks for any help!
John
facebook.com/chicagoraspberryjam - join in the fun
Majoring in ChemE at the University of Houston.
hexelpdkk
Re: Printing to file from arduino serial output
Thu Mar 21, 2013 7:24 pm
You can use pyserial to handle the serial comms http://pyserial.sourceforge.net/shortintro.html, then just standard python file io to write the file. If you need more details, just ask.
cae2100
Thu Mar 21, 2013 7:32 pm
and here's a simple program to get user input and outputs it to a file
fob = open('output.txt', 'w')
blahvar = raw_input()
print fob.write(blahvar)
fob.close
If it isnt smoking and blown into pieces, it's not pushed far enough yet. :P
http://cae2100.wordpress.com
bltsandwich1
Thu Mar 21, 2013 9:59 pm
So using Pyserial all I would have to do is flash the arduino with a code that included a serial output of the temperature reading, and then run that sketch with the arduino connected to the pi correct?
Thanks for pointing me to pyserial!
John
hexelpdkk
Fri Mar 22, 2013 7:15 pm
Yes, absolutely. Just check which port the Arduino uses - run dmesg just after you plug it in, and it will be in the output at the end.
cae2100
Fri Mar 22, 2013 7:28 pm
most of the time, arduino is attached to /dev/ttyACM0
Return to “Python”
