IAmRaspbian
goAgain?
Tue Mar 19, 2013 7:59 am
I've been trying to create a very simple password system, but when I ran it the first time... I noticed a problem, I didn't know how to make it go back to the start. So, should I be using goAgain?
If it helps, here's the code;
password = "password"
attempt = raw_input("Enter password: ")
if attempt == password :
    print "Correct Password"
else :
    print "Incorrect Password"
Thanks on advance,
ejfield
Re: goAgain?
Tue Mar 19, 2013 8:26 am
Try this:
attempt = ""
while attempt != password :
    attempt = input("Enter password: ")
    print ("Incorrect Password")
print( "Correct Password")
Note that the two print statements are in Python3 format - you will probably want to remove the brackets.
...and raw_input changed to input for the same reason!
IAmRaspbian
Re: goAgain?
Tue Mar 19, 2013 8:27 am
Thanks, ejfield :)
IAmRaspbian
Re: goAgain?
Tue Mar 19, 2013 8:32 am
Completely off topic question , but what does != do?
gordon77
Re: goAgain?
Tue Mar 19, 2013 8:35 am
It means NOT equal to.
IAmRaspbian
Re: goAgain?
Tue Mar 19, 2013 8:37 am
Thanks Gordon
IAmRaspbian
Re: goAgain?
Tue Mar 19, 2013 8:45 am
How to I use wait? I find when I run it, everything rifles through, is it wait(10) and ":" at the end, or have I got it all wrong?
attempt = ""
    wait(10)print ("Incorrect Password"):
wait(10)print( "Correct Password"):
gordon77
Re: goAgain?
Tue Mar 19, 2013 9:05 am
Try time.sleep(x)
Add import time
at the start
And use time.sleep(x)
X = seconds
IAmRaspbian
Re: goAgain?
Tue Mar 19, 2013 9:17 am
I've ran into a problem with time.sleep(X)
time.sleep(10) print "Correct Password"
It tells me the print, is an invalid syntax. Do I need to put the
time.sleep(10)
on it's own line?
gordon77
Re: goAgain?
Tue Mar 19, 2013 9:18 am
Yes
IAmRaspbian
Re: goAgain?
Tue Mar 19, 2013 9:21 am
Thanks :D
IAmRaspbian
Re: goAgain?
Tue Mar 19, 2013 9:29 am
One final question, how do I make the password invisible, or dots?
Here's the coding so far;
import time
    time.sleep(0.5)
else :
    time.sleep(0.5)
mefarmer
Re: goAgain?
Tue Mar 19, 2013 1:56 pm
Hello IAmRaspbian,
I see you are just now learning Python and I think that is great!
It's always good for us old timers to see someone join in our fun.
From the level of questions you are asking it looks like:
1) you are thinking about how to structure your program
2) having problems with the syntax
3) need to learn some of Pythons modules
I am sure many on this forum would love to answer all your questions but...
we would be cheating you out of the thrill of learning it yourself.
Those first moments when you type in a program and runs as expected are awesome.
Experience will come through practice. Check out this website http://www.learnpython.org/
You can go through the tutors and type into the interpreter at the bottom and see the results.
There are many resources available to learn, so look around for one that fits your style.
Return to “Python”
