guyute74
Round up and ignore the digits after the decimal
Mon Mar 18, 2013 2:09 am
I am running a python script to read temperatures and am getting temperatures up to ten thousandths accurate on my print function.
What is the best way to eliminate this?
def read_temp():
lines = read_temp_raw()
while lines[0].strip()[-3:] != 'YES':
time.sleep(0.2)
equals_pos = lines[1].find('t=')
if equals_pos != -1:
temp_string = lines[1][equals_pos+2:]
temp_C = float(temp_string) / 1000.0
temp_F = temp_C * 9.0 / 5.0 + 32.0
return temp_F
mefarmer
Re: Round up and ignore the digits after the decimal
Mon Mar 18, 2013 4:03 am
I love Python, but this is one of those task that seems like it should be simple but isn't.
You have to use string formatting....
Here is an example from the interpreter:
>>> long_float = 1.234123493536346541275341234
>>> # ok this will round to the 4th digit after the decimal
>>> round(long_float,4)
1.2341
>>> # ok that seems like what you want huh?
>>> round(long_float,6)
1.2341230000000001
>>> # yea here's the problem floats are not exact
>>> # this has to do with the way numbers are stored in binary
>>> # it will vary across processors.... Blah!
>>> "%.6f"%(round(long_float,6))
'1.234123'
>>> # so we can use string formating to save the day, but it is a str.
>>> # lets convert this back to a float
>>> float("%.6f"%(round(long_float,6)))
1.2341230000000001
>>> # arghhhhhh!
>>> # lesson of the day if you just need a nice string repr
>>> # of a float it's easy enough, but floats don't always play nice
If you want to just truncate to a specific digit just use string format.
If you care about rounding round first and then string format.
guyute74
Tue Mar 19, 2013 12:33 pm
Outstanding! I will start monkeying with this soon.
I admit, I was hoping for an easier answer but as you say... I guess this is what I will learn about Python.
mefarmer
Tue Mar 19, 2013 1:37 pm
I forgot to mention that this is not a Python specific problem with floats.
There is also a "decimal" module that I always seem to forget about.
From the module:
""" This is a Py2.3 implementation of decimal floating point arithmetic based on
the General Decimal Arithmetic Specification:
http://speleotrove.com/decimal/decarith.html
and IEEE standard 854-1987:
http://www.cs.berkeley.edu/~ejr/project ... 7/dir.html
Decimal floating point has finite precision with arbitrarily large bounds.
The purpose of this module is to support arithmetic using familiar
"schoolhouse" rules and to avoid some of the tricky representation
issues associated with binary floating point. The package is especially
useful for financial applications or for contexts where users have
expectations that are at odds with binary floating point (for instance,
in binary floating point, 1.00 % 0.1 gives 0.09999999999999995 instead
of the expected Decimal('0.00') returned by decimal floating point)."""
It is in the python standard library.
jojopi
Tue Mar 19, 2013 1:42 pm
mefarmer wrote:>>> "%.6f"%(round(long_float,6))
'1.234123'
You just want one of:
>>> "%.6f" % long_float
'1.234123'
>>> "{:.6f}".format(long_float)
'1.234123'
It is not usually desirable to round intermediate results. Keep everything at its highest precision except when you print it.
(If you need to represent exact things like currency then avoid fractions by denominating your variables in cents or hundredths of cents. The problem converting to and from binary only affects digits to the right of the decimal point. It is because the decimal fraction 0.1 is infinite recurring bicimal 0.0001100110011…)
mefarmer
Tue Mar 19, 2013 3:07 pm
Excellent point, and he asked:
I showed him two ways to do it. One just truncating the results and the other rounding to your lowest desired digit and then truncating.
Good example of Python 3 format I still use Python 2.x on all my work.
mefarmer
Tue Mar 19, 2013 3:28 pm
I just read your post title again. Do you want to ignore all the digits after the decimal? If so just round and then convert to an int.
>>>temp = 98.523443244234
>>>print int(round(temp))
99
jojopi
Tue Mar 19, 2013 3:33 pm
mefarmer wrote:I showed him two ways to do it. One just truncating the results and the other rounding to your lowest desired digit and then truncating.
All of your methods round, and so do mine. There is no need to round twice.
>>> "%.3f" % 1.5555555555555555
'1.556'
>>> "%.0f" % 1.5555555555555555
'2'
mefarmer
Tue Mar 19, 2013 4:09 pm
You are right and I must ask for forgiveness now :)
I had forgotten that it rounded on it's own.
Thank you for the correction.
pyedish
Sat Jan 20, 2018 3:41 pm
I came across this topic when searching for a solution to the same problem; handling the output from a Dallas temperature probe. The solutions offered seemed rather complex for me as someone new to Python although I have some programming experience.
The output of the probe is a six digit string e.g. 123456 representing a temperature of 12.3456 degrees Celsius. Dividing this number by 10000 gives 12.3456 which is a greater degree of resolution than most people require. If we divide the output by 1000 and round the result we get 123; dividing this by 10 gives 12.3 which is an adequate resolution for most purposes. This can be achieved by using the expression
round ( temp /1000) / 10
Return to “Python”
Who is online
Users browsing this forum: mjrobot and 20 guests
