staple
Running python script from SSH
Tue Mar 05, 2013 12:46 am
Hi there,
I have a python script I have been writing which slideshows images on my R-Pi, I'd like to be able to run it from SSH if possible.
When I run the script with
> python node.py
I get an error...
  File "node.py", line 65, in <module>
    root = MyApp()
  File "node.py", line 7, in __init__
    Tk.__init__(self)
  File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1688, in __init__
    self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: no display name and no $DISPLAY environment variable
I am guessing this is something to do with the way I am connected remotely and the desktop are separate?
Is it possible to run the script via SSH and have it affect the desktop?
cae2100
Re: Running python script from SSH
Tue Mar 05, 2013 2:42 am
programs that use GUIs cant be started from SSH terminal, either start it on the raspberry pi or through vnc server
If it isnt smoking and blown into pieces, it's not pushed far enough yet. :P
http://cae2100.wordpress.com
jojopi
Tue Mar 05, 2013 2:55 am
If you have already logged in on the Pi and started X, over SSH you can do:
DISPLAY=:0 python node.py
(With most GUI programs this is not very useful, because you need the Pi's mouse and keyboard to control the program so you may as well start it using them. However, it might make sense for a slideshow, or any program that needs no control or can be controlled remotely.)
texy
Wed Mar 06, 2013 9:36 pm
LittlePi
Fri Mar 08, 2013 3:31 pm
cae2100 is I'm afraid wrong.
Programs that use a GUI can definitely be run over ssh, by including the -X switch in the ssh command.
For instance
ssh -X pi@192.168.rest.ofaddress
Note that the X has to be a cap (lower case x means something else).
Return to “Python”
