Hi!
I got a project at school to finish, and I thought, that I could make it on my RasPi. But the problem is, that I'm absolute newbie in programming. I need to connect mic and diode to RasPi, and light it up with claping.
Any ideas where I should start?
Re: Using mic to light up diode -> newbie
well, the easiest way is to just use a mic element and comparator to tell when a loud sound, like a clap is detected and it'd send a pulse out, and into a pin on the raspberry pi, just make sure you use a voltage divider so it doesnt go over 3.3v, but have a python program detect it using input(), and use that trigger to turn on/off an LED.
here's an example circuit that Ive used in a few projects, it was taken from a robot that detects a tap on it, or clap, or loud noise to activate.
another alternative is hooking up a usb sound card and using pyaudio to detect the audio, and turn on the LED pin, but the only thing about that is the sensitivity of it.
If it isnt smoking and blown into pieces, it's not pushed far enough yet.
http://cae2100.wordpress.com
