how to use time as a varible
Posted: Tue Feb 19, 2013 6:24 am
by thatbakerguy
import RPi.GPIO as GPIO
import time
import os
#!/usr/bin/env python
# Example for RC timing reading for Raspberry Pi
# Must be used with GPIO 0.3.1a or later - earlier verions
# are not fast enough!
#import RPi.GPIO as GPIO, time, os
DEBUG = 1
GPIO.setmode(GPIO.BCM)
GPIO.setup(22, GPIO.OUT)
def RCtime (RCpin):
    reading = 0
    GPIO.setup(RCpin, GPIO.OUT)
    GPIO.output(RCpin, GPIO.LOW)
    time.sleep(.5)
    GPIO.setup(RCpin, GPIO.IN)
    while (GPIO.input(RCpin) == GPIO.LOW):
        reading += 1
    return reading
while True:
    if RCtime(18) > 500:
        print (RCtime(18))
        GPIO.output(22, True)
    if RCtime(18) < 500:
        print ('less than')
        GPIO.output(22, False)
GPIO.cleanup()
okay I'm using this code turn an led on and off, using values provided by a photocell and a 1microf capacitor.
It works great as is, but i have two problems.
1.) I need a way to stop it on command, I want it to read values until I tell it to stop, for now it just reads values until I close the terminal.
2.) Right now it makes an instantaneous decision on wether or not to take action on the led, I would like it to run for an indefinite amount of time and have it set to record a value every (n)seconds, if the values over a period of time (n) are greater than a set value it needs to turn on the led, if they are lower i need it to turn it off.
I have basic knowledge of other languages but i have no experience with using time as a variable, and I'm new to python as a whole. I'm not asking you to write it for me, i just need help in the right direction. mainly the syntax is what I'm weakest at.
Re: how to use time as a varible
Posted: Tue Feb 19, 2013 8:23 pm
by alexeames
You've already got
import time
and
time.sleep(.5)
in the code. the number in the time.sleep() function is the time in seconds that you want to wait for.
Change the number for what you want and that part of it's sorted.
You can halt the program at any time with CTRL+C, but it sounds like you're looking for something more subtle than that.
Posted: Wed Feb 20, 2013 2:00 am
by thatbakerguy
yeah im trying to make like a while loop statement you know like "press s to stop"
Posted: Wed Feb 20, 2013 5:46 pm
by -rst-
