Hove
Re: RPIO: An extension of RPi.GPIO with interrupts, PWM and
Sun Jan 19, 2014 8:12 pm
You need to call RPIO.setmode() and RPIO.setup() before you can play with inputs outputs etc.
RPIO.setup is the call which sets your pin to an input or output, and sets whether you want pull-up / down resistors
www.pistuffing.co.uk - Raspberry Pi and other stuffing!
michaelperakis
Sun Jan 19, 2014 10:44 pm
The error code received:
/home/pi$ sudo python test4.py
File "test4.py", line 8, in <module>
RPIO.add_interrupt_callback(19, do_something, edge='both', threaded_callback=True)
File "/usr/local/lib/python2.7/dist-packages/RPIO-0.10.0-py2.7-linux-armv6l.egg/RPIO/__init__.py", line 217, in add_interrupt_callback
threaded_callback, debounce_timeout_ms)
File "/usr/local/lib/python2.7/dist-packages/RPIO-0.10.0-py2.7-linux-armv6l.egg/RPIO/_RPIO.py", line 125, in add_interrupt_callback
gpio_id = _GPIO.channel_to_gpio(gpio_id)
RPIO.Exceptions.InvalidChannelException: The channel sent is invalid on a Raspberry Pi (not a valid gpio)
What do you mean by the "complete code?" -- This is the complete code...
michaelperakis
Sun Jan 19, 2014 11:15 pm
ok, got it.
Added the missing code and also threaded=True @ RPIO.wait_for_interrupts(), but now nothing is happening when I press the button...
I was expecting to have an output signaling the 'button pressed' change of state...
Please advice since obviously I am missing something...
Hove
Mon Jan 20, 2014 7:55 am
2 things:
if the button is connected to pin 18, the the RPIO.add_interrup_callback() needs to always refer to pin 18, not 17 or 19.
Also pin 18 is the BCM pin numbering scheme (pins on the chip) so actually the button needs to be connected to GPIO pin 12 (which is where BCM pin 18 is connected to.
michaelperakis
Mon Jan 20, 2014 9:37 pm
Yes, the modified code is the following:
import RPIO
RPIO.setup(18, RPIO.IN)
RPIO.setmode(RPIO.BCM)
def do_something(gpio_id, value):
    print("New value for GPIO %s: %s" % (gpio_id, value))
RPIO.add_interrupt_callback(18, do_something, edge='rising',debounce_timeout_ms=100)
RPIO.wait_for_interrupts(threaded=True)
So, I would expect to see the message: New value for GPIO 18: 1, but the program simply runs and finishes without waiting for input. Should I include the code in a while loop? But if true, isn't this what we would like to avoid in the first place?
Hove
Mon Jan 20, 2014 10:01 pm
If you want to wait for interrupts, and for the code to wait until it happens, you need "threaded = False" I think.
michaelperakis
Mon Jan 20, 2014 11:06 pm
Hove wrote:If you want to wait for interrupts, and for the code to wait until it happens, you need "threaded = False" I think.
Changed to threaded = False but still the code isnt runing as expected since I get a sequence of messages:
New value for GPIO 18: 1 and when the button is pressed, the sequence just stops then when released, it starts again...
I would expect nothing to happen until the button was pressed. I thought that was the whole idea of interrupts...
Hove
Tue Jan 21, 2014 7:36 am
Please post your latest code - the code below will just exit when you press a button, but that is not what you are describing.
michaelperakis
Thu Jan 23, 2014 9:22 pm
Sorry for not responding a few days now, I was busy with other issues.
I have fixed the code, which I am posting naked without any unnecessary rems:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(18, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
print "Waiting for rising edge on port 18"
try:
    	GPIO.wait_for_edge(18, GPIO.RISING)
    	print "\nRising edge detected. Now your program can continue with"
    	print "whatever was waiting for a button press."
except KeyboardInterrupt:
    	GPIO.cleanup()       # clean up GPIO on CTRL+C exit
GPIO.cleanup()           # clean up GPIO on normal exit
But the issue is this line of code: GPIO.wait_for_edge(18, GPIO.RISING)
When this runs, the system hangs (pauses) and waits for the input (18) to happen.
What should I do to proceed to other code and when input 18, or other input happens, to run specific subs?
BR
Hove
Fri Jan 24, 2014 8:29 am
There's a few options here:
- run your other code in another thread
- use event_detected in your main thread instead of wait for edge
- move the code you have into a thread callback, and do your other stuff in the main thread
Details here:
http://sourceforge.net/p/raspberry-gpio ... ki/Inputs/
Return to “Python”
