Page 3 of 4
Re: RPIO: An extension of RPi.GPIO with interrupt management
Posted: Mon Mar 11, 2013 1:23 pm
by BerryPicker
metachris wrote:I will implement that.
I look forward to it. If holding off change notification is to become the built-in RPIO switch bounce strategy, it might help understanding if you included in the documentation an example to clarify proper usage. May I suggest that RPIO.add_interrupt_callback provides the 'delayed one shot' function, to flag as an interrupt the change of edge(s), but that it is left to Python code to double check what's happened by 'read input from gpio' as required. This is the way I would usually have software cope with a button pusher or switch flipper trying to break the expected operation.
Posted: Mon Mar 11, 2013 5:13 pm
by sej7278
any chance we can get this merged into gpio, or at least packaged into a .deb so it could eventually get into the raspbian repo's?
Posted: Tue Mar 12, 2013 2:00 am
by metachris
What I can do now is to add .deb packages to the RPIO build toolchain, to produce them with every release. See where it goes from there; I'm open to suggestions.
Posted: Tue Mar 12, 2013 9:31 am
by sej7278
metachris wrote:What I can do now is to add .deb packages to the RPIO build toolchain, to produce them with every release. See where it goes from there; I'm open to suggestions.
lovely. i did have a go at packaging it myself last night but failed miserably using py2dsc, i guess because it contains elements of C too it needs to be packaged in the normal way.
edit: i tried using dh_make and debuild like the regular GPIO package, it seemed to build all the .so's etc. but the package ends up just containing the docs and not the binaries lol!
also there's an unused py_set_pullupdn() function at line 304 of source/c_gpio/py_gpio.c that needs removing before it will even compile and README.rst needs to be added to the includes in MANIFEST.in
Posted: Wed Mar 13, 2013 4:47 pm
by sej7278
any chance of getting 0.9.5 debs, i still can't get them to build even with your debian files!
this is really starting to look more useful than the regular GPIO module, although i'm not 100% sure of using try/finally instead of an if statement or while loop and how to cleanup afterwards, i'm thinking of something like this:
#!/usr/bin/env python
import RPIO
from threading import Thread
from time import sleep
Thread(target=RPIO.wait_for_interrupts).start()
def gpio_callback():
    """callback routing from gpio input4"""
    print "button pressed"
try:
    RPIO.setmode(RPIO.BCM)
    RPIO.setup(4, RPIO.IN)
    RPIO.add_interrupt_callback(4, gpio_callback, edge='rising', debounce_timeout_ms=20)
    while 1:
        # do my stuff that needs to be in a loop, call the callback and return to the loop
        sleep(1)
finally:
    RPIO.stop_waiting_for_interrupts()
    RPIO.cleanup()
Posted: Wed Mar 13, 2013 8:07 pm
by metachris
I'm just running the latests tests right now; RPIO 0.9.5 will be out within the hour; i'll post here when its available. Your code looks good I think; you can replace the Thread with `RPIO.wait_for_interrupts(threaded=True)`, and you don't need to call setmode(BCM) since that's already done by default.
I'll spend some more thought on the shutdown procedures...
Posted: Wed Mar 13, 2013 8:54 pm
by metachris
I've just added a few bugfixes, and released RPIO 0.9.6! This is what changed:
  • Added ``debounce_timeout_ms`` argument to ``RPIO.add_interrupt_callback(..)``
  • Added ``threaded`` argument to ``RPIO.wait_for_interrupts(..)``
  • Interrupt callbacks now receive integer values ``0`` or ``1`` instead of strings
  • Interrupt callbacks with edge=``rising`` or ``falling`` only receive the correct values
  • Added ``RPIO.close_tcp_client(fileno)``
  • Debian .deb packages
  • License changed to GNU Lesser General Public License v3 or later (LGPLv3+)
Install/update RPIO with easy_install for Python 2.x:
$ sudo easy_install -U RPIO
For Python 3.x:
$ sudo easy_install3 -U RPIO
Debian packages are available at http://metachris.github.com/rpio/download/latest. You can install them with `sudo dpkg -i python-rpio_0.9.6_armhf.deb`. Links:
Feedback is much appreciated!
Posted: Wed Mar 13, 2013 9:54 pm
by sej7278
the debouncing stuff seems to help a bit, really i think i need to buy some better switches though, as sometimes it works fine, other times it goes high-low-high no matter what the debouncing is set to (10/20/50/100ms) that might also be down to the speed of the pi too i guess, as it appears to fix itself if you leave it for a couple of seconds before pressing the switch again (or press the switch harder!)
rpio-curses is useful for when you don't want a bunch of print statements in your code
my momentary spst switches (i've tried 3 of the same type):
Posted: Wed Mar 13, 2013 10:59 pm
by metachris
By the way, this is the code you posted before how I'd write it with the current RPIO 0.9.6:
import RPIO
def gpio_callback(gpio, val):
try:
    while 1:
        sleep(1)
finally:
    RPIO.cleanup()
Edit: next thing i'm going add is auto-shutdown of RPIO when the script is done, in order to not having to have the finally block in the above example.
Posted: Thu Mar 14, 2013 12:59 am
by sej7278
metachris wrote:By the way, this is the code you posted before how I'd write it with the current RPIO 0.9.6:
here's my full code with your changes taken into account, essentially when you press the button it pauses or plays the music. i've still got the lcd code using GPIO, i guess its fine to mix it using a different namespace.
at the moment i've not got it running as a daemon, so have to ctrl-c or kill the process, which means gpio isn't tidied up, but i can't see how you'd deal with auto-shutdown in that case. i'm not so keen on the try...finally bit myself either.
are you forking the main GPIO code or merging in changes, as 0.9.7 seems to be based on old 0.4.2a code, is there nothing to be gained in moving to 0.5.0a?
# import modules
from subprocess import *
from time import *
from hd44780 import hd44780
import RPIO
def gpio_callback(gpio_id, val):
    call(["mpc", "-q", "toggle"])
# add rising edge callback to gpio4 input
RPIO.add_interrupt_callback(4, gpio_callback, edge='rising', debounce_timeout_ms=100)
# always start playing as soon as we load
call(["mpc", "-q", "play"])
# initialise lcd
lcd = hd44780()
prev_lcdtext = ''
# main program loop
try:
    while 1:
        # get current status
        p = Popen(["mpc", "current"], stdout=PIPE)
        current = p.communicate()[0]
        if current:
            # playing - print mp3 as band/track, or print station
            lcd_text = current.rstrip().replace(' - ', '\n', 1)
        else:
            # stopped - print date/time
            lcd_text = strftime('%a %d %b %H:%M',localtime())
            lcd_text += '\nRaspberry Radio!'
        # update lcd if new track or time
        if lcd_text != prev_lcdtext:
            lcd.message(lcd_text)
        prev_lcdtext = lcd_text
        # pause to reduce load/flicker
        sleep(1)
finally:
    # reset gpio
    RPIO.cleanup()
Posted: Thu Mar 14, 2013 1:05 am
by metachris
Ah great you mention the daemon. If you kill it with a signal, the finally block isn't executed anyway. But it does not really matter, since the call to cleanup is optional (ie. no harm done when not calling it). The stop_waiting_for_interrupts() call is also unnecessary since it just stops the epoll thread, which the kill itself takes care of too. So you can safely remove the whole try..finally block :) (edit: in case you quit with Ctrl+C, the epoll-thread keeps running because stop_waiting_for_interrupts(..) has not been called. RPIO 0.9.7 (coming tomorrow) automatically shuts it down when the script exits).
Re RPi.GPIO 0.5.0: nothing to be gained from this release; it's essentially just the new (not yet fully working) interrupt methods. I'm always willing to merge useful changes into RPIO, and am communicating ideas and suggestions for the other way as well.
Posted: Thu Mar 14, 2013 3:11 pm
by metachris
I've just released RPIO v0.10.0 with the following updates:
  • Auto-cleanup on exit (also shuts down RPIO.wait_for_interrupts(threaded=True))
  • Bugfix in cpuinfo.c: correctly trim over-voltage header
  • rpio-curses: help shows raspberry sysinfo
  • switched argument ordering of wait_for_interrupts to (wait_for_interrupts(threaded=False, epoll_timeout=1))
  • Added RPIO.Exceptions (list of C GPIO exceptions)
The most significant change is that all interrupt interfaces are shut down automatically by RPIO, there is no need to call cleanup_interrupts(..) manually anymore. If 'wait_for_interrupts(threaded=True)' is running, this thread will automatically quit if your main script quits.
You can install and/or update RPIO as usual with easy_install like this:
Alternatively you can use 'pip', or 'dpkg' with the debian packages.
As always, feedback is much appreciated!
Re: RPIO: An extension of RPi.GPIO with interrupts, PWM and
Posted: Thu Mar 14, 2013 3:15 pm
by metachris
Re sedj7278: with RPIO 0.10.0, you can write the code like this:
import RPIO
while 1:
    sleep(1)
Posted: Thu Mar 14, 2013 6:18 pm
by sej7278
metachris wrote:Re sedj7278: with RPIO 0.10.0, you can write the code like this:
yup, that's what i came up with, its all working fine now with 0.10.0, interestingly it took a timeout of 200ms to get the switch 100% reliable (confirmed here where it says 157ms) i thought for some reason the maximum was 100, but looking at the code its just n/1000
next up i've got to figure out how to do something else on a long-press of the same button!
Posted: Thu Mar 14, 2013 6:24 pm
by metachris
Glad it's working for you! I don't see any debounce issues on my circuits when I use a proper pullup or -down resistor. If you are sure your wiring is correct (eg. like in this example), and you've double checked that no cold soldier points exist, the conclusion would be that the buttons are indeed causing the problems (in which case the question is whether to workaround the buttons restrictions or to get better buttons : ).
Posted: Thu Mar 14, 2013 7:20 pm
by sej7278
metachris wrote:Glad it's working for you! I don't see any debounce issues on my circuits when I use a proper pullup or -down resistor. If you are sure your wiring is correct (eg. like in this example), and you've double checked that no cold soldier points exist, the conclusion would be that the buttons are indeed causing the problems (in which case the question is whether to workaround the buttons restrictions or to get better buttons : ).
the linked site proves the buttons are a bit naff, also i'm not using a pull-up (or rc circuit) due to using the voltage-divider, but as i recall i didn't have issues when using the 10k pull-up.
i've got long-press working now btw:
    """hold gpio4 to stop or press to play/pause"""
    sleep(0.5)
    if RPIO.input(4):
        call(["mpc", "-q", "stop"])
Posted: Tue Mar 19, 2013 9:30 am
by joshmosh
Hi Chris,
it has been quiet on this topic for a while, so I will take the chance to chip in ;)
With version 0.10 I am back in the game, because with the new features you have included, it fits very well to my requirements. The core of my project is now working, based on your RPIO - thanks a lot.
I have a suggestion for an (in my view) improvement and a question.
The question: how would I include timer events as callbacks ? I would like to integrate routines that are called at a certain time, very similar to cronjobs, but integrated in my server program. You have already included TCP callbacks, which - at least for me - is very useful.
The suggestion: currently I need to run my Python code with root privileges. I know that this cannot be avoided, because of the access to the GPIO pins. But perhaps the part which requires root privileges can be sort of isolated ? In the MagPpi magazine issue 7 there is an article dealing with GPIO. The author has written a small program in C that exports or imports GPIO pins and this of course requires root privileges. But all other handling can be done with standard user logins.
Perhaps something to think about ?
Again, thank you for the additional features you have added - it makes RPIO a real useful tool for me !
Please keep up the good work.
Cheers
Josh
Posted: Tue Mar 19, 2013 12:27 pm
by sej7278
joshmosh wrote:The suggestion: currently I need to run my Python code with root privileges. I know that this cannot be avoided, because of the access to the GPIO pins. But perhaps the part which requires root privileges can be sort of isolated ? In the MagPpi magazine issue 7 there is an article dealing with GPIO. The author has written a small program in C that exports or imports GPIO pins and this of course requires root privileges. But all other handling can be done with standard user logins.
really though, all you could do with gpio's without root would be reading from them.
you most certainly should never be allowed to set them up or write to them as a regular user and the magpi script is just using setuid, so i don't see the point really.
if you're worried about running as root, then either setuid your program or setup sudoers carefully.
Posted: Tue Mar 19, 2013 1:01 pm
by jojopi
sej7278 wrote:really though, all you could do with gpio's without root would be reading from them.
With the kernel /sys/class/gpio interface, you can give a user or group read or write access to specific GPIO pins. It is just unfortunate that some libraries insist on direct access to the hardware registers instead, and have given little thought to privilege delegation themselves.
Posted: Tue Mar 19, 2013 2:16 pm
by joshmosh
My point is that the only piece of code in the magpi example is pretty small and not too complex, so the chance that it runs havoc is minimal. It is only used to export or unexport pins, nothing else. After having exported a pin, you can read and (!) write these (and only these) exported pin as standard user. If this user program does evil things, potential harm is limited.
I am worried about running as root because I want to protect the system from myself and my bad code ;), not against attacks from the outside.
Josh
Posted: Wed Mar 20, 2013 9:30 pm
by dauhee
yes timer event callbacks would be fantastic. it would enable me to use RPIO as the framework for my application. This library has saved me so much work already !!!!
Posted: Sun Mar 24, 2013 6:11 pm
by pzc
Hi Chris,
Great job on RPIO!
I have my RPi connected to a Gertboard and I'm using it to create a (Knight Rider) KITT-like chasing dot pattern on the LEDs.
I'm using your PWM function to modulate the LED brightness in an attempt to replicate 'bulbs' (with slow on and slow off) rather than the instant on-off of the LEDs.
I get weird results when I try to write an individual PWM waveform to each of the 12 LEDs. All the LEDs seem to follow the waveform written to the last LED instead of their own waveform...
Maybe I'm taking RPIO into unchartered territory?! ("Here there be dragons")
Many thanks in advance for any help you can offer...
# Produce a KITT-like display on the Gertboard LEDs
# Install all 12 "out" links on the Gertboard
# Connect:
#   GP7-B12
#   GP8-B11
#   GP9-B10
#   GP10-B9
#   GP11-B8
#   GP17-B7
#   GP18-B6
#   GP27-B5
#   GP22-B4
#   GP23-B3
#   GP24-B2
#   GP25-B1
from RPIO import PWM
import numpy as np
try:
    # define the list of ports for the Gertboard
    ports = [25, 24, 23, 22, 27, 18, 17, 11, 10, 9, 8, 7]
    # define the LED intensities
    # (10 longer than required, 5 extra 'each end')
    # (so sequence starts with all LEDs switched off)
    intens = [200,400,1990,400,200,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
    # make a copy of ports and then reverse it as we need both directions
    ports_rev = ports[:]
    ports_rev.reverse()
    delay = 1                   # set a delay
    servo = PWM.Servo()         # Set up PWM
    for loop in range(10):      # repeat n times
        for step in range(len(intens)):
            for port in range(len(ports)):  # set the intensity of each port
                servo.set_servo(ports[port], intens[(port+5)])
            intens = np.roll(intens, 1)
            sleep(delay)
            for port in range(len(ports_rev)):  # set the intensity of each port
                servo.set_servo(ports_rev[port], intens[(port+5)])
            sleep(delay)
except KeyboardInterrupt:           # trap a CTRL+C keyboard interrupt
    print 'CTRL+C received...'
for port in ports:                       # cleanup
	servo.stop_servo(port)
Posted: Wed Apr 24, 2013 12:02 am
by saltydog
pzc wrote: I get weird results when I try to write an individual PWM waveform to each of the 12 LEDs.
Did you ever sort that out?
I get a similar thing when dimming multiple LEDs. Dimming a single led works fine. Results are not as expected when dimming multiple LEDs, using both PWM.servo and low level PWM method/s.
Chris
Posted: Sun Jan 19, 2014 7:18 pm
by michaelperakis
Dear all,
I use the following code:
import RPIO
def do_something(gpio_id, value):
    print("New value for GPIO %s: %s" % (gpio_id, value))
RPIO.add_interrupt_callback(17, do_something, edge='rising')
RPIO.add_interrupt_callback(18, do_something, edge='falling')
RPIO.add_interrupt_callback(19, do_something, edge='both', threaded_callback=True)
RPIO.wait_for_interrupts()
as posted at the beginning but I get an error about GPIO 17,18,19 not being setup (or something similar).
Does anyone know why this is happening?
I am using 18 as input having a button connected on and have changed the above code such as where 17 -> 18 and 18 ->17 in order to detect the rising effect when pressing the button.
Any suggestions?
BR
M.
Posted: Sun Jan 19, 2014 8:08 pm
by texy
michaelperakis wrote:Dear all,
import RPIO
Any suggestions?
BR
M.
you need to show us the complete code, not just a snippet, and also a paste of the error message you are getting. Is it something like :
RuntimeWarning: This channel is already in use, continuing anyway. Use GPIO.setwarnings(False) to disable warnings.
Texy
