RaspberryPiBeginners
"GPIO.output(farray, True)" doesn't work
Sat Feb 16, 2013 11:54 pm
I'm trying to turn on multiply LEDs based on vaiables in an array, it does not work as i get this error when using this code.
If i try and run
"GPIO.output(array, True)"
File "test_array.py", line 41, in <module>
TypeError: an integer is required
However if i use below it works.
"GPIO.output(array[0], True)"
I think it's because array outputs [1,2,3] where array[0] outputs 1.
I need to to loop/do for all items in array. Or something like do until array is empty.
Click here for my unofficial YouTube Channel > http://goo.gl/oFYBD
bgreat
Re: "GPIO.output(farray, True)" doesn't work
Sun Feb 17, 2013 12:24 am
As the error message states, function GPIO.output() requires an integer first argument, not an array.
If you want to set an output for all pins in an array, try:
for pin in array:
  GPIO.output(pin, True)
Enjoy!
Bill
Sun Feb 17, 2013 8:49 am
That you very much that solved my problem.
Return to “Python”
