RaspberryPiBeginners
Problems with handling "socket.gaierror"
Sun Feb 10, 2013 3:50 pm
I'm trying to run some python code that looks to see if DNS resolution is working. When it works this is great. But when it cant resolve it stoops the script from running and bombs out with this error.
File "testingfile.py", line 10, in <module>
externaldns = socket.gethostbyname('www.google.co.uk') # result from hosts file
socket.gaierror: [Errno -5] No address associated with hostname
The Error isn't the problem it's the fact that the code/scripts stops running.
Ideally i don't want it to print the error to screen and not to stop the script from running.
This code is what im working with
#!/usr/bin/python
# Import required libraries
import urllib2
import os
import socket
#Check For DNS
print "---------------"
print "External DNS"
print externaldns + " << Local DNS"
if "socket.gaierror" in externaldns:
    print "External DNS resolution failed"
Click here for my unofficial YouTube Channel > http://goo.gl/oFYBD
cae2100
Re: Problems with handling "socket.gaierror"
Mon Feb 11, 2013 5:40 am
you could try something like this, and it'd just skip over the socket part when it cannot connect.
#!/usr/bin/python
import urllib2
import os
import socket
    #Check For DNS
try:
except:
If it isnt smoking and blown into pieces, it's not pushed far enough yet. :P
http://cae2100.wordpress.com
Mon Feb 11, 2013 2:55 pm
thanks for that dude! works!
Return to “Python”
