rurwin
Re: UART
Fri Mar 22, 2013 9:52 am
It works for me in Windows:
import serial
usbport = '/dev/ttyAMA0'
ser = serial.Serial(usbport, 9600, timeout=1)
ser.write("Raspberry pi\r\n")
x = ""
while chr(3) not in x:
	x = ser.readline()
	print x
ser.close()
Which line has the error? For example, if I put the old error back in:
File "sertest.py", line 6, in <module>
while 3 not in x:
TypeError: 'in <string>' requires string as left operand, not int
it tells you the line number (6) and what is on that line. Otherwise I am guessing which line is at fault and what is on it.
thivtulz
Re: UART
Mon Mar 25, 2013 1:03 am
this is my code..
import serial
x = ""
   x = ser.readline()
   print x
ser.close()
here the error after i ran the given source code...
File"hello.world.py", line 9, in <module>
TypeError: argument of type 'builtin_function_or_method'  is not iterable
in python it doesn't works.Now my objective is once i run the python code in RPi i must send a text to the PC and must received the text which is type in the PC and display on RPi.
Please help me on it ..
dhuertas
import serial
Thu Apr 25, 2013 2:26 am
hey so when I tried writing the code, it gives me an error saying that there is no module named serial when I say
import serial. Did you guys download pyserial for this?
rurwin
Re: UART
Thu Apr 25, 2013 2:37 am
Yes. For some unaccountable reason there is no serial module in the otherwise incredibly well stocked Python standard library.
yapodurt
Re: UART
Fri Jul 12, 2013 9:41 am
I get the same error that dhuertas was getting. I have installed pyserial. I can even get import serial to work in the Python Shell but not when I try it within a script. Can anyone help me?
Davespice
Contact: Twitter
Re: UART
Fri Jul 12, 2013 10:10 am
Return to “Python”
