mypifi
piface twitter chicken
Sat Jan 26, 2013 2:32 pm
hi there
i have a piface and have tried unsucessfully to get the twitter chicken demo working. i have downloaded the twitter api s andworks in terminal but when i try and run the twitter_chicken it comes up with an error in line 21 twitter.Api anyone know why and how to solve this?
many thanks in advance.
davef21370
Re: piface twitter chicken
Sat Jan 26, 2013 3:05 pm
I've no idea how to solve this but couldn't ignore a post entitled "piface twitter chicken" :)
Classic!
Apple say... Monkey do !!
-rst-
Sat Jan 26, 2013 5:59 pm
Seeing the full error message might help...?
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
mypifi
Sat Jan 26, 2013 8:32 pm
the error is as follows:
File "./twitter_listen.py", line 50 in <module>
main()
File "./twitter_listen.py", line 21, in main
api = twitter()
Typeerror: "module" object is not callable
davef21370
Sun Jan 27, 2013 2:12 pm
Is "twitter" the module? As in...
import twitter
...at the top of your script.
If so you can't say api=twitter as twitter is the module, not a class. It would need to be api=twitter.something
I may be very wrong but let us know how you get on.
Cheers.
Dave.
-rst-
Sun Jan 27, 2013 3:58 pm
If it's this library: http://code.google.com/p/python-twitter/ , it should be:
import twitter
api = twitter.Api()
mypifi
Sat Feb 02, 2013 8:53 pm
Hi thanks for the help the error is still the same apart from the last line which reads:
AttributeError: 'module' object has no attribute 'Api'
-rst-
Mon Feb 04, 2013 11:35 am
Hmm, did you too fall into the naming trap: is your own script named twitter.py? If so, it obscures the 'module twitter' from the library - the interpreter thinks your script is 'module twitter'... rename your script (in typical tutorial way, maybe 'mytwitter.py') and it works...
mypifi
Mon Feb 04, 2013 4:02 pm
Hi no its called twitter_user.py it's one of the demo scripts with the pi face add on
mypifi
Mon Feb 04, 2013 4:14 pm
-rst-
Mon Feb 04, 2013 4:59 pm
Nothing obvious sticks out... :?
davef21370
Mon Feb 04, 2013 6:41 pm
Code looks fine, just been here http://code.google.com/p/python-twitter/ and everything matches what you're doing.
I'd try opening the twitter module and looking for the Api class, if it's there your code should work, if it isn't then assume dark forces are at work and re-install the module.
mypifi
Mon Feb 04, 2013 7:14 pm
Many thanks there is a api.py in twitter folder is that the one?
tonyhughes
Mon Feb 04, 2013 7:15 pm
smstext wrote: i have a piface
Sorry to hear that.
I went to the nightclub last week, and there were some dogfaces. So you are not alone out there.
mypifi
Mon Feb 11, 2013 12:20 am
Decided today to reflash the card with the image for piface and re download twitter and try again, now it works and I have done a quick write up with a video http://smstextblog.blogspot.co.uk/2013/ ... t.html?m=1
Return to “Python”
