how to control 2 or more motors with async using PIGPIO Library?
Posted: Wed May 12, 2021 8:13 am
by muhosevo
hi everyone,
i have 2 NEMA 34 stepper motors and i want to control them different frequency/PWM at the same time. these are my example codes. In this code just one motor works. i do not know why 2 motors are not running. how can i fix the problem?
import pigpio
pulse_1 = 21
dir_1 = 20
pulse_2 = 5
dir_2 = 17
pi = pigpio.pi()
pi.set_mode(pulse_1, pigpio.OUTPUT)
pi.set_mode(dir_1, pigpio.OUTPUT)
pi.set_mode(pulse_2, pigpio.OUTPUT)
pi.set_mode(dir_2, pigpio.OUTPUT)
class MOTOR_1:
    def __init__(self, ramp):
        self.generate_ramp(ramp)
    def generate_ramp(self, ramp):
        pi.wave_clear() #delete all waveforms
        length = len(ramp)
        wid = [-1] * length
        for i in range(length):
            frequency = ramp[i][0]
            half_periods = int(500000 / frequency)
            wf = []
            wf.append(pigpio.pulse(1<< pulse_1, 0, half_periods))
            wf.append(pigpio.pulse(0, 1<<pulse_1, half_periods))
            pi.wave_add_generic(wf)
            wid[i] = pi.wave_create()
        chain = []
            steps = ramp[i][1]
            x = steps & 255
            y = steps >> 8
            chain += [255, 0, wid[i], 255, 1, x, y]
        pi.wave_chain(chain)
class MOTOR_2:
    def __init__(self,ramp):
        #pi.wave_clear() #delete all wave forms
        length = len(ramp)
        wid = [-1] * length
            wf = []
            wf.append(pigpio.pulse(0, 1<<pulse_2, half_periods / 2))
            wf.append(pigpio.pulse(1<< pulse_2, 0, half_periods / 2))
        chain = []
            steps = ramp[i][1]
            x = steps & 255
            y = steps >> 8
motor_1 = MOTOR_1([[1000, 2400],
                [2500, 2400],
                [5000, 2400],
                [7500, 2400],
                [9500, 2400],
                [10000, 2400],
                [9500, 2400],
                [8000, 2400],
                [6500, 2400],
                [5000, 2400],
                [4000, 2400],
                [2000, 2400],
                [1000, 2400]])
motor_2 = MOTOR_2([[1500, 9600],
                  [1700, 9600],
                  [2300, 9600],
                  [2500, 9600],
		  [2700, 9600],
		  [3000, 9600]])
Re: how to control 2 or more motors with async using PIGPIO Library?
Posted: Wed May 12, 2021 10:28 am
by joan
There can only be one wave being sent at any one time. If you send a new wave it will replace any existing one. You can drive multiple GPIO with one wave so you can certainly drive more than one stepper with one wave.
Posted: Wed May 12, 2021 11:31 am
by muhosevo
is it possible to make different acceleration and different frequency and different pulses can you write a couple of code or fix the given example?
Posted: Thu May 13, 2021 6:32 am
by pootle
Yes absolutely possible, but not simple. I have a library here that drives multiple steppers using waves using A4988 style driver chips. - you have not said what driver hardware you are using tho'.
I use a generator to yield pulse timings for each motor independently, and then merge these into a single stream of timings. It would be difficult to adapt your code to create merged waves.
Posted: Thu May 13, 2021 11:11 am
by muhosevo
İ looked your library, you succeded great job, Congrats! I am using Nema34 stepper motor as i said, my drives is CWD860. Actually i want to make my own cnc control software, like mach3 but not 3 axis, may be up to 10 axes. And i dont wan to be dependent any external library. But i will definetely benefit from your library, if you want to share a couple of codes related with multiple gpio using different pwm/frequemcy each other, i will be glad to.
