mrdrake
Whats wrong with my LCD code?
Fri Jan 18, 2013 5:32 am
from Adafruit_CharLCD import Adafruit_CharLCD
lcd = Adafruit_CharLCD()
lcd.begin(16,1)
lcd.clear()
lcd.message("hello world")
I'm bloody stumped.
The Adafruit example works though so I have no idea whats going on.
bgreat
Re: Whats wrong with my LCD code?
Fri Jan 18, 2013 1:59 pm
Are you getting an error message when you attempt to run or no display?
First thing I noticed is the 'lcd.begin(16,1)'. This says you are using a 16 character by 1 line display. Is this correct? The typical display is a 16x2 display, which would need a 'lcd.begin(16,2)' line.
Are you running like this (assuming lcdhello.py is your program name)?
sudo python lcdhello.py
If you want to run directly, you need to do add the '#!/usr/bin/python' line at the beginning:
#!/usr/bin/python
from RPi import GPIO
lcd.begin(16,1)
lcd.clear()
GPIO.cleanup()
I also added the 'GPIO.cleanup()' to eliminate the warnings on subsequent runs.
And then make it executable using:
chmod +x lcdhello.py
Then you can run it using:
sudo ./lcdhello.py
Enjoy!
Bill
mrdrake
Sat Jan 19, 2013 4:43 am
./testing.py: 5: ./testing.py: Syntax error: "(" unexpected (expecting "do")
This came up when I copied your code and then made it executable. I'm really confused right now, just changing the Adafruit example makes it not work at all. And by not work, it runs perfectly, shows no errors on the terminal, but nothing shows up on the LCD. I know its not the wiring because both of the Adafruit examples work perfectly when I use them without changing them. Grrr....
texy
Sat Jan 19, 2013 7:53 am
Please the full code that works and the full code that doesn't work.
Texy
bgreat
Sat Jan 19, 2013 1:07 pm
Yes, please post the code.
Also, what editor are you using for modifying the code? Seems that the save code source is being corrupted. The files you are attempting to execute must be 'plain text' without any formatting added by a word processing style application. If you are editing on another computer and transferring to the Raspberry Pi (seems possible since you have /var/mail listed in the file path), you must use a program that stores as plain text.
Enjoy!
Bill
mrdrake
Sun Jan 20, 2013 4:50 am
I'm using Sublime Text 2. I've never had a problem with it, Python, and the raspberry pi before. I'm transferring it with Cyberduck through SFTP (also never had a problem).
This works (from their repo)
#!/usr/bin/python
from subprocess import *
from time import sleep, strftime
from datetime import datetime
cmd = "ip addr show eth0 | grep inet | awk '{print $2}' | cut -d/ -f1"
lcd.begin(16,1)
def run_cmd(cmd):
        p = Popen(cmd, shell=True, stdout=PIPE)
        output = p.communicate()[0]
        return output
while 1:
	lcd.clear()
	ipaddr = run_cmd(cmd)
	lcd.message(datetime.now().strftime('%b %d  %H:%M:%S\n'))
	lcd.message('IP %s' % ( ipaddr ) )
	sleep(2)
This doesn't
#!/usr/bin/python
cmd = "ip addr show wlan0 | grep inet | awk '{print $2}' | cut -d/ -f1"
lcd.begin(16,1)
def run_cmd(cmd):
        return output
while 1:
	lcd.clear()
	lcd.message('IP')
	sleep(2)
The only thing I changed was taking away the IP address at the end of the second line. Adafruit_CharLCD.py is cloned from github and is the same for both (excepting changing the pin numbers to match Rev. 2 raspberry pi)
mrdrake
Sun Jan 20, 2013 4:57 am
I hadn't changed the 3rd pin from 21 to 27. Thank you for your help, how do I go about getting this thread closed?
texy
Sun Jan 20, 2013 8:00 am
Glad you got it sorted. You don't have to close the thread.
Texy
Return to “Python”
