LexYeow
How to have accurate time.sleep()
Tue Dec 29, 2020 7:15 am
Hi guys, currently trying out the timelapse project. However, the sleep() function isn't exactly accurate. When I want to take a picture every 5 seconds, sleep(5), the time taken to snap a picture would always be much longer than 5 seconds. Anyone knows how to have accurate timing?
pcmanbob
Re: How to have accurate time.sleep()
Tue Dec 29, 2020 10:35 am
Hi.
As Linux is not a real time OS you can never guarantee that timing will be accurate,
but you could try using code like this to replace your time sleep.
import time
now = time.time()
start = now
end = now + 5
while now < end:
    now = time.time()
print ("time up ", now - start)
I guess it depends on how accurate you need the 5 second delay to be.
Edit...
Also have you allow for the time it takes to actually take the picture in your timing calculations, if you want exactly 5 seconds between pictures.
take picture - timer
 1 second ---- 4 sec
 over all 5 seconds
some thing like this
import time
while true:
    now = time.time()
    start = now
    end = now + 5
    print ("take picture")
    # replace line above with code to take picture
    while now < end:
        now = time.time()
includes the time it take to actually take the picture in the overall timings.
jahboater
Tue Dec 29, 2020 10:43 am
You have not said what language you are using.
As above, you wont get precise timings with an OS like Linux but it should be fairly close (within milliseconds or better).
Try nanosleep() in C.
See "man nanosleep" for details.
davidcoton
Tue Dec 29, 2020 10:50 am
"sleep" (or "nanosleep") will add a delay from the end of one process to the start of the next.
If you need accurate timing start to start, use pcmanbob's technique.
If that isn't close enough, you'll probably need to use a real time kernel, but don't ask me how.
LTolledo
Tue Dec 29, 2020 11:02 am
if you need accurate timing....use a microcontroller...not a microcomputer....
Some people be like:
jahboater
Tue Dec 29, 2020 11:51 am
Using the loop will just run the CPU core flat out doing nothing, and of course since it still relies on getting the time will have a similar overheads. At least use a decent clock such as "clock_gettime(CLOCK_MONOTONIC)"
Any sleep system call has an overhead of course.
Measurement is a wonderful thing, for nanosleep() on a Pi4, I get:
$ ./try
5 secs is 5000141106 nanosec
5 secs is 5000138320 nanosec
5 secs is 5000137329 nanosec
5 secs is 5000133192 nanosec
5 secs is 5000130459 nanosec
5 secs is 5000140250 nanosec
that is, the overhead is around 130 to 140 micro seconds - about 0.002%
Which may be good enough and presumably is better than the OP's quoted "much longer than 5 seconds"
It may also be that the OP's long timings are nothing to do with the sleep and may be in some other part of the code.
You could likely improve on 0.002% by using a micro-controller, but is it worth it?
PiGraham
Tue Dec 29, 2020 12:36 pm
For timelapse with raspistill have you read the docs?
https://www.raspberrypi.org/documentati ... melapse.md
Or in Python, using picamera:
https://picamera.readthedocs.io/en/rele ... -sequences
rpiMike
Tue Dec 29, 2020 1:23 pm
Another option that can take a picture approx every 5 seconds excluding time taken for picture.
import time
nextPic = time.time()+5
while True:
    if time.time()>nextPic:
        nextPic += 5
        print('take picture (must take less than 5 seconds)')
    time.sleep(0.001)
twostage
Tue Dec 29, 2020 4:54 pm
I think it is just a matter of compensating for the time taken for the picture to take in the sleep. Assuming the picture taking can be buried in a while loop :-
snaptime = time.time()
while True:
	snaptime = snaptime + 5# desired time is 5 seconds since the last time through or wait 5 seconds if it is first time through
	sleeptime = snaptime - time.time()# work out how long to sleep until the next camera snap
	if sleeptime >  0: # haven't missed the slot
		time.sleep(sleeptime)
		# take the picture and do some other stuff if needed
	else:
		#ooops took to long taking the last picture so just skip to the next one
PiGraham
Wed Dec 30, 2020 11:21 am
Out of curiosity I did a quick test of raspistill -tl time-lapse option
with these results:
-rw-r--r-- 1 pi pi 2699301 2020-12-30 10:53:09.378878731 +0000 image0000.jpg
-rw-r--r-- 1 pi pi 2697500 2020-12-30 10:53:14.441429941 +0000 image0001.jpg
-rw-r--r-- 1 pi pi 2722885 2020-12-30 10:53:19.423913342 +0000 image0002.jpg
-rw-r--r-- 1 pi pi 2721842 2020-12-30 10:53:24.416378444 +0000 image0003.jpg
-rw-r--r-- 1 pi pi 2626125 2020-12-30 10:53:29.408823637 +0000 image0004.jpg
-rw-r--r-- 1 pi pi 2642521 2020-12-30 10:53:34.401251811 +0000 image0005.jpg
-rw-r--r-- 1 pi pi 2627651 2020-12-30 10:53:39.393665469 +0000 image0006.jpg
-rw-r--r-- 1 pi pi 2631567 2020-12-30 10:53:44.396071564 +0000 image0007.jpg
Intervals:
5.06
4.98
4.99
4.99
4.99
4.99
5.00
Seems pretty good to me.
davidcoton
Wed Dec 30, 2020 4:43 pm
Out of curiosity I did a qhick test of raspistill -tl timeplase option
Very curious quick spelling lapses there! :lol:
paddyg
Sat Jan 02, 2021 11:51 pm
This has cropped up on this forum a few times. @rpiMike's answer is a good way to do it. You can modify it to give you accuracy of only a few micro seconds and it won't 'accumulate errors'. i.e.
MARGIN = 0.00001 #10us
DELAY = 5.0
num = 1
start_time = time.time()
next_pic = start_time + DELAY
while True:
    tm = time.time()
    if (tm + MARGIN) > next_pic:
        num += 1 # integer counter
        next_pic = start_time + num * DELAY
        print('take picture at {:.6f}'.format(tm))
    time.sleep((next_pic - tm) * 0.9) # sleep for 90% of the remaining time
PiGraham
Sun Jan 03, 2021 9:57 am
... it won't 'accumulate errors'.
That's a good point. It may be important to distribute images on a realtime schedule. You can store the start time and calculate the target time for each capture as start_time_date + interval * i++. Rather than just using the time of the previous capture plus interval. That way if some captures take a different time to complete it doesn't affect the timing of subsequent images.
paddyg
Sun Jan 03, 2021 10:25 am
@PiGraham, yes you are absolutely right, and that was actually the conclusion from the previous thread (now you remind me!). Python converts the + 5 to a float value and then you get cumulative float approximation errors. I will edit above - might as well make it as correct as possible. For most purposes I don't suppose it matters really but someone might find these posts when looking for something that did require an accurate sleep.
Return to “Python”
